07-03-2009, 10:12 PM | #1 |
body lift Qs
does body lift kits come with " body bushings" as well as the lift pucks or do i need to get them seperate. can someone post pic of ther 1" or 2" body lift please, visual is always better for my simple mind. thanks
07-04-2009, 12:53 AM | #2 |
Re: body lift Qs
seperate
1971 Chevy Blazer CST 4X4 2012 Camaro 2SS/RS 2007 Avalanche 4X4 |
07-04-2009, 04:54 AM | #3 |
Re: body lift Qs
Typically just the blocks.
I'd go with poly body bushings if your going to run a body lift. |
07-04-2009, 01:33 PM | #4 |
Re: body lift Qs
hows the ord 1" lift and body bushings, i figure when i replace my worn out body bushing as well and put in the 1" lift i might get a 1.5 lft of were im at now i didnt want to go with a 2" body and i couldnt find any smaller till i found the k5 site i already have a 8" spring lift.
07-04-2009, 03:02 PM | #5 |
Re: body lift Qs
Wow, what size tire are you planning on running? 8" spring lift plus a body lift, must be you don't want to modify the fenders eh? What spring lift are you running?
07-04-2009, 06:34 PM | #6 |
Re: body lift Qs
i used to have 39.5"s and was gonna cut the fenders but after my wife surprised me with my paint job i dont want to cut now, the fenders are still in ok shape. i now have 38"s but not muchroom for flex. im not looking for alot the truck is problly only on trails 30% of the time. i think there superlift i bought used and stickers is there another way to tell thanks for interest
07-04-2009, 10:05 PM | #7 |
Re: body lift Qs
One thing I did was turned the rear springs around to move the rear axle back another inch to give more clearence of the front corner of the fender.
07-05-2009, 09:48 PM | #8 |
Re: body lift Qs
wat kinda springs did u have? stock lifted.....
07-06-2009, 05:57 AM | #9 | |
Re: body lift Qs
Normally that's not the case, I got spanked twice on that move, 1) all the time I wasted & 2) I couldn't center up my axle any more. |
07-07-2009, 10:42 PM | #10 |
Re: body lift Qs
ill have to try that this wkend my rearend sits forward also. hope i can im not running these tire any more, they were tooooo big. i now have 38"s thanks
07-07-2009, 11:44 PM | #11 |
Re: body lift Qs
Is that just 3 bolts holding that wheel on?
Tony Johnson -- '71 Blazer w/L-31 Vortec 350, SM465, NP205, performer intake, edelbrock 1406, HEI, 4" lift, Boyd EFI tank, Vintage A/C My Blazer -- |
07-09-2009, 10:38 PM | #12 |
Re: body lift Qs
ya i had to get all new and longer wheel studs i got them all in now
07-10-2009, 12:43 AM | #13 |
Re: body lift Qs
4" all spring on mine, funny thing was I was replacing the 4" lift with blocks that my truck came with to the new all spring lift and it looked like the shackles were centered on the springs the first one went in with ease the second was a total PITA and took forever to get on. I then noticed the extra clearence so I swaped the first around to match the second. works perfect and like I said moved the whole axle back about a full inch.
07-10-2009, 04:07 PM | #14 |
Re: body lift Qs
I didn't know about swapping the rear spring around, going to have to try that.
You can also try ORD's zero rate springs: |
07-10-2009, 04:12 PM | #15 |
Re: body lift Qs
I did the one inch body from ORD, but don't have a good side pic. I will take one this weekend. I'm going to run stronger bolts
07-10-2009, 06:18 PM | #16 |
Re: body lift Qs
well got some stuff yesterday and today, new ord body bushins with 1" body lift, rear hangers and front shackles. also got stuff for hydro clutch ( linkage) conversion. follow thread, will be many pics and updates and prolly some questions i have some fun weekends ahead. a buddy and a case of bur.
please any input would be appreciated. thanks |
