![]() Join Date: Jan 2009
Tubular Motor Mount Perches????
Can I get some info on tubular motor mount perches? I'm installing a 6.0L (ls2). Where is the best place to get them? Also which motor mounts are being used with this conversion? Can I also get some info about setting the engine back 1 inch, pro's/con's? Thanks Dbrasco
Re: Tubular Motor Mount Perches????
ECE makes a kit for LS motor swaps. Look in the 'new items' menu . . ....
www.earlyclassic.com
