07-04-2009, 06:22 PM | #1 |
Year One Crate Motor
I was wondering if any of you guys have used the Year One Crate Motor?It is a 350 over 400 hp dyno!It seems like a great deal for 2,995.Thanks
07-04-2009, 06:28 PM | #2 |
Prestige Worldwide
Re: Year One Crate Motor
I have a good friend who used to work for YearOne and they have had really good luck with that engine.....
He told me that they had not had hardly any problems out of the PowerCrate 350 model. He said they had some issues out of the big blocks but not the small block stuff.... but keep in mind that it's been a year or so since he worked there. Last edited by Number98; 07-05-2009 at 09:44 AM. |
07-04-2009, 06:34 PM | #3 |
Thanks 98,It seems lke a great deal!
07-04-2009, 06:49 PM | #4 |
One of the members posted a couple of videos of the start up of that engine within the last week. Sounded good!
07-04-2009, 06:56 PM | #5 |
Thank You! I'll see if I can find it! They say it produces over 430 ft. lbs.of torque and you get your engine's dyno sheet.
07-04-2009, 08:12 PM | #6 |
Gearhead and audio junkie
I bought one! 403.6 hp at 5800 RPM and 413 ftlbs of torque at 4100RPM
Pretty darn happy with the thing. everything looks really nice, they didnt cut any corners, Comes with a dyno sheet and a list of things like spark plugs,reccomennded oil, and total timing and other stuff to. Showed up in a heck of a crate too was pretty impressed. I'd buy one again! |
07-05-2009, 05:41 PM | #7 |
AWESOME!!!What did it take to complete the motor?How long to ship?You are going to have to keep us up to date...PLEASE!
07-05-2009, 07:37 PM | #8 |
One really good thing about them is the roller cam. You don't have to worry about a flat tappet cam dieing with mainstream modern oil. And it's already got the initial run done, so you know it'll work.
'72 cheyenne super step, '05 long bed gmc |
07-05-2009, 08:56 PM | #9 |
Well it needed the distributor i just used a GM performance parts HEI dizzy. Used my old water pump (it was new) ,pulleys, thermostat housing, ehaust manifold or headers, spark plugs, wires, Shippin took about 2 and a half weeks and it was crated REALLY well even wrapped in a plastic bag, all opening were plugged and the intake manifold was taped shut so no dust could get it, even comes with an oil filter. Only problem i've had with it is finding a dipstick for it, the only ones local part stores have is dipsticks for 1967-79 SB and you need an 80 and up dipstick.
07-05-2009, 09:20 PM | #10 |
Is the block similar to a GM 350, meaning, can you put anything that would fit on a regular Chevy smallblock would fit on that motor?
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD Click here to support the board Philippians 4: 6-7 |
07-05-2009, 09:51 PM | #11 |
Yes, and it comes with a new flexplate so you don't have to buy a new one if your old motor had a 2 piece rear seal style crank.
07-05-2009, 09:57 PM | #12 |
Does it use a mechanical fuel pump?
07-06-2009, 12:46 PM | #13 |
07-06-2009, 12:48 PM | #14 |
yep only thing that doesn't line up is if u have A/c with the vortec heads you need an aftermarket bracket. Also the only thing ive had a problem with is the dipstick. Nobody but summit sells a 1980 and up dipstick and they are all pretty expensive. other than that everything is universal
07-06-2009, 12:59 PM | #15 |
R.I.P. E.S.L.L.
Kind of odd that it comes with an oil filter but not a dipstick.
1971 Custom C/20 1970 CST 20 1970 C/30 Flatbed 1983 C/30 Dually 2015 Corvette Z51 2021 Corvette Z51 1991 Cadillac Hearse 1982 Cadillac Eldorado Biarritz 2000 Porsche Boxster S 2020 Jeep Gladiator 1973 VW Thing 1973 Plymouth Satellite wagon 1963 Baja Bug 1959 Bug Dune Buggy 1970 Baja Bug 1987 Jaguar XJ 350. R.I.P. El Jay R.I.P Jessie. R.I.P Grumpy. Every day is a gift from God. |
07-06-2009, 01:04 PM | #16 |
07-08-2009, 06:11 AM | #17 |
mikajo39,
So have you been able to get that "bad boy" on the road?How does that motor feel? |
07-08-2009, 12:14 PM | #18 |
Almost!, I'm really close, hassled with some transmission cooling lines last night but got the cooling system finished. Just need bolt the torque converter to the flexplate add transmission fluid, radiator fluid,throttle linkage,and gas and it'll go for its first test run. But the engine sounds like it means buisness and free revs pretty dang quick.
07-15-2009, 07:20 PM | #19 |
Any updates?The suspense is killing me!LOL.
07-16-2009, 01:09 AM | #20 |
It's on the road! other than some tranny troubles this little thing is a monster!pulls hard and the throttle response is pretty killer too.
07-16-2009, 01:39 AM | #21 |
If you just got a limited slip, maybe some 28x9.5reet radials, and left the original style hub caps, that would almost be as good as the oklahoma farm truck for sleeper-ness
07-16-2009, 01:51 AM | #22 |
haha I'm gettin a posi hopefully sometime soon, along with some radial t/a's P295/50r/15 I think they'd fit and I'll keep the old hubcaps! sleeper for life!
07-16-2009, 01:54 AM | #23 |
Aren't the original steel wheels 6.5 or 7 inches wide? If you're running those there's no way it'll look right if it works
07-16-2009, 02:01 AM | #24 |
I could get the wheels widend i suppose, hmm what to do
07-16-2009, 07:53 AM | #25 |
Dang it! I am at work and You Tube won't come up.I'll have to wait till I get home.
