Old 07-04-2009, 08:00 PM   #1
Hoffman65burb
Hoffman65burb's Avatar
Universal Lowering block
Hey,
I went down today and bought my self a UNIVERSAL lowering block kit from the local parts store. Well after installing the blocks, i went to go put the u bolts on.... Well they definatly dont work, they are too wide and too short
I just want re-assurance that these are the wrong u-bolts, or am i doing somthing wrong??
too wide
but they work this way???????????????????
1978 GMC Jimmy
454bbc
Turbo400
NP205
3.73 gears
4inch lift
33's
Hoffman65burb is offline   Reply With Quote
Old 07-04-2009, 08:05 PM   #2
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: Universal Lowering block
I would say wrong U bolts. See how they are round on mounts at the top of your spring if you reverse them and put a plate across the top of your springs it MIGHT bolt up. You should have square top u bolts like the originals.
Old 07-04-2009, 08:08 PM   #3
aerotruk63
aerotruk63's Avatar
Another thing if you mount the block between the top of the diff and the bottom of the spring your raising the truck.
Old 07-04-2009, 08:13 PM   #4
aerotruk63
aerotruk63's Avatar
Lowering on your set up you would transfer the diff on top of the springs. I don't think the block is going to help you.
Old 07-04-2009, 08:21 PM   #5
toomanytoyz
Luv the Crewcabs
toomanytoyz's Avatar
That is Correct, You need a Rear Shackle Drop Kit to Lower the Rear with a Leaf Spring Set Up like you Have. That will be much easier than relocating the Axle above the Springs........
Just take that Kit Back & Look for a Shackle Drop Kit.
Good Luck, Rick
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
toomanytoyz is offline   Reply With Quote
Old 07-04-2009, 08:53 PM   #6
Hoffman65burb
Thats what i asked when i opend up the box in the store, he said it pulls the axle up to the springs, Im pretty close with the guys that work there os if it doesnt work out i can always return it, thanks for the info ill go back tomarrow
1978 GMC Jimmy
454bbc
Turbo400
NP205
3.73 gears
4inch lift
33's
Old 07-04-2009, 10:32 PM   #7
Shane
Shane's Avatar
those are for mini trucks ....
Shane is offline   Reply With Quote
