Suspension drop questions for my '78 C10
Hello ......
I recently purchased a very original 1978 stepside C10. It is all STOCK right down to the plaid tan bench seat & smaller than usable sport mirrors. My ideas or "plan" is to lower it with a quality drop spindle & front spring. The rear with a flip kit & relocated shox. Although I like the factory steel wheels, caps & rings the 235 sized tires are a bit inadiquite. I'm thinking 255/60/15's on the front & either 275 or 295 rears. Eventually I'd like a set of TTII's or Coys but I'll spend cash on the "kits" first. Your thoughts on equipment & possible vendors?? Thanks. Ratty 46 I'll post a pic or 2 as soon as my son re-sizes the pictures I have. |
Resistance is Futile
Re: Suspension drop questions for my '78 C10
Performance Online and Classic Performance Parts have everything so you could eyeball the goods. There are also vendors on this site, as well.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
Thank you - I'll check them out ......
Ratty 46 |
#4 | |
So .... (Shane) ... you would suggest?
Ratty 46 |
Early Classic would be my vendor of choice for spindles and springs.
I can also help you get whatever parts you need!
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
#8 | |
6.0 powered square
summit racing will have every thing you need and summit brand coils and spindles are re branded ground force parts
and for tire combo I would go with 215/70 27" tall and 275/60 28" tall
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 Last edited by flamingbig10; 07-05-2009 at 12:46 AM. |
Laid Lo
I like the 255/60 front and 275/60 rear combo when running 15s on these trucks.
BFG Radial T/As and Torque Thrust IIs for my ride. I have been looking at the POL flip out back for my 72. I'm not a fan of bolt-in C notches but lots of folks run them. Not sure about them being sponsors but both POL and CPP have banner ads on this site.
Semper Fi, Jeff ![]() '72 C10 - lays frame '07 Sand Rail - ecotec powered '05 2500HD - tows stuff '67 VW Bug - gas saver '01 Jeep TJ - rock crawler |
McGaughys, Bell tech, DJM, Western Chassis, or CPP on the spindles. Western Chassis on the rear flip kit & c-sections/shock relocators.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 07-05-2009 at 08:52 AM. |
#12 | |
#13 |
I must say ....... thanks all for the info. I will be checking these out & posting some progress pix soon.
Thanks. Ratty 46 |
#14 |
6.0 powered square
yes I am, now I ready to build a truck all by myself
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
