Wind Wings ?? One Piece windows?
i have a 53 Chevy truck and wanted to change out the wind wings to one piece windows. Is there a kit out there to do this? Or has anyone done this process and have any direction or advice?
thanks in advance for any help! Byrne66 |
Re: Wind Wings ?? One Piece windows?
Don't know when the wing windows started but 47 48 are one piece
so you should be able to use those. Check cl auto parts and there is a guy in Santa Clara that sells 47 up stuff to do the job. I like wing's myself. |
Registered Chevy Owner
The wings started in '51. You could find earlier doors to.
Love is fleeting, but Chevy trucks are forever!!!! ![]() 1970 Chevy CST C10 long box 350/400 ![]() 2008 Chevy Silverado short box 4x4 Had; 1951 Chevy short box 307/T5 1988 Chevy shot box 4x4 350/350 1971 Chevy C10 long box 4x4 350/350 1971 Chevy C20 long box 350/350 1971 Chevy C10 long box 350/350 |
I have a 1951. It's the first year for the wing windows and the last year for turn down door handles. I Haven't really looked that close at mine but I do know that the wings are removable and replacable and you can see the kits at www.bowtiebits.com and other places, if you would like to see all the parts involved. I only said all that, to say this. I'm guessing you could remove them from you exsiting doors and convert to full windows but you may need to also replace your window regulators. Anybody feel free to jump in here if I'm wrong. I have not actually investigated this possiblity, it's just an assumption.
av8tr33337 AKA Bartman ![]() Bartman's Ad-S10 Chassis Swap http://67-72chevytrucks.com/vboard/s...d.php?t=415418 My First Youtube Video http://www.youtube.com/watch?v=B6hSt...eature=channel More Pics of the 51 Project http://s668.photobucket.com/albums/v...hassis%20Swap/ 1951 3100 Pickup |
Byrne, i'm going to do the same change you are but i have a different solution I have a 52 chevy but i also bought a 50 chevy 5 window cab, I thinking the doors will just swap out but the latches and strickers are different I think all the catalogs sell different ones so if anyone has any helpful points that would be great.
#6 | |
get my projects finished. ALWAYS TRYING TO CHANGE SOMETHING. |
Thanks everyone I really appreciate all the advice gives me a little homework to do.
hang on those wind wings are nice. i kept mine and love how they work. if they're 1/2 open all the wind goes around the door window and it's quieter than when they are closed (less wind in your ear!). also if you don't have ac you can really pump in the outside air if there wide open. I would think about it.....
GT
Greg 1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school http://67-72chevytrucks.com/vboard/s...=215079&page=5 |
I have not seen anyone selling a kit for a one piece window for these trucks. I have seen people graft in the front window channel from the early doors to the vent window doors but it looks like too much of a PITA.
I kept my vent windows and enjoy them. I did a rebuild on mine which you can find on this link. http://www.chevytrucks.org/tech/ventwindowrebuilt.htm Keep the vents. |
I'm currently working on converting a set of '52 doors to single windows as well. So far I've gutted both doors with the exception of the mid door support which is common on both. I've had to drill out the spot welds on the front channel and the wiper strip that runs along the top, since it's all one peice. The winders are different as well since the '47's use a scissor type winder while the '52 has a single lever winder.
I opted to lose both winders completely and will be mocking up and installing power windows from a '93 Grand Cherokee (the winders look dramatically the same as a '47 with motor assist). It should be a simple spacer job but will require that the doors have skins to cover the mounting bolts. I found the easiest way is to have both doors side by side so you can judge what has to be moved or altered. But if you can find a set of single window doors in the first place that are in great shape... by all means go that route! Cheers, Ted.
'51 Chevy Build - In the design stages Aut viam inveniam aut faciam - I will either find a way or make one. If you don't have time to do it right the first time, when will you... My new build - https://67-72chevytrucks.com/vboard/...70#post8958970 |
#11 | |
http://www.customclassictrucks.com/t...ion/index.html |
#12 | |
add that to the end of the url.. |
