how do i take my guage bezel off
how to i get my guage bezel off and the ignition cylinder off, and those nuts around the headlight switch and washer switch and how do i get the 12v plug out.
thanks guys
I wouldnt have it any other way...CHEVROLET! ALL throttle, NO bottle!!! Theres NO replacement for displacement Current Rides 2006 Silverado ![]() ![]() Previous Rides 2003 Silverado 1992 Silverado Last edited by chevysbest92; 07-05-2009 at 08:50 PM. |
Re: how do i take my guage bezel off
Installing a Tach in a '64-66 Chevy Truck
That article has pictures on how to take out the instrument panel. Take your time and check everything on the back is disconnected, before you yank on it. a few image of my instrument panel, out of the truck, it will give you an idea of what all is back there Good luck, -W Last edited by Woogeroo; 07-05-2009 at 09:08 PM. |
![]() Join Date: Aug 2008
Are you wanting to remove your instrument panel? The outer bezel is secured to the panel with small bolts from the back side.
Ignition Switch- Put in key, then depress pin through the small hole with a paperclip. Turn slightly to the left and the key cylinder should pull out. Then you can unscrew the bezel around the switch and it can be removed. Nuts around switches- Remove knobs and then with a small punch or screwdriver- GENTLY tap one of the slots to move it in a counter clockwise motion. After initial loosening it should be able to hand screwed out. If you are wanting to pull the whole panel- you will need to remove all the switches- Light, Wiper and Cig lighter first. Just did that tonifgt on my '66. 12V Pug- ???? |
thanks guys, by 12v plug, i mean cig lighter,
and i tried tappin on the nuts holdin the switches, they wont budge, any ideas
I wouldnt have it any other way...CHEVROLET! ALL throttle, NO bottle!!! Theres NO replacement for displacement Current Rides 2006 Silverado ![]() ![]() Previous Rides 2003 Silverado 1992 Silverado Last edited by chevysbest92; 07-05-2009 at 09:13 PM. |
got em off, woo hoooo
I wouldnt have it any other way...CHEVROLET! ALL throttle, NO bottle!!! Theres NO replacement for displacement Current Rides 2006 Silverado ![]() ![]() Previous Rides 2003 Silverado 1992 Silverado |
sure i have school tomorrow, but my truck is more important haha
I wouldnt have it any other way...CHEVROLET! ALL throttle, NO bottle!!! Theres NO replacement for displacement Current Rides 2006 Silverado ![]() ![]() Previous Rides 2003 Silverado 1992 Silverado Last edited by chevysbest92; 07-05-2009 at 10:56 PM. |
It's all about priorities...
