Old 07-05-2009, 09:33 PM   #1
lotik
drag it like you stole it
project rebuild
I posted a couple of months ago that I was getting started back on the truck. Well I've gotten a little further. The new suspension is pretty much done and the truck is sitting good. I just got a motor to use for mock up, and I can finish the other pieces that will be mounting to the frame (airtank, valves, etc.) A list of what has been done:
Raised Crossmember 2"
Rack and Pinion Steering
Triangulated 4-Link
New Wheels and Tires - Wheel Vintiques Smoothies
I'm attaching a shot of before, to bring back some memories, and some current pictures.
negative camber //LA\\
lotik is offline   Reply With Quote
Old 07-05-2009, 09:34 PM   #2
lotik
Re: project rebuild
Old 07-05-2009, 09:36 PM   #3
72chevyfleet
Learning As I Go
72chevyfleet's Avatar
Re: project rebuild
ur not gonna keep that bed are you
1972 Chevy C-20 Longbed 2wd Granny Low with a Crate 350: Air Gap Manifold, Edelbrock 600cfm, HEI, Headers to a 40 series flow (soon to be dual again)
72chevyfleet is offline   Reply With Quote
Old 07-05-2009, 09:38 PM   #4
lotik
Re: project rebuild
definitely.
Old 03-02-2013, 05:30 PM   #5
lotik
Re: project rebuild
Going to put all the pics in the build thread.
Old 03-02-2013, 05:30 PM   #6
lotik
Re: project rebuild
Old 03-02-2013, 05:31 PM   #7
lotik
Re: project rebuild
Old 03-02-2013, 05:31 PM   #8
lotik
Re: project rebuild
Inner fender wells.
Old 03-02-2013, 05:42 PM   #9
lotik
Re: project rebuild
Here some pics as it sits now.
Got most of the body panels bolted on.
New PB hood hinges installed.
Smoothed the inside of the bed.
Fixed gap on tailgate.
Added some frenched taillights.
Old 03-02-2013, 05:43 PM   #10
lotik
Re: project rebuild
Need to get the steering column mounted properly. There is not much room under the dash with the brake setup.
