Old 01-05-2003, 11:59 PM   #1
Mike C
Mike C's Avatar
My budget Hi-Lift jack mount pics
Here are some pics of my budget Hi-Lift jack mount. First, the whole thing:
Here's a closeup of the front and back with jack attached:
And without the jack...
The "pins" are grade 8 bolts with the head chopped off. On the front I just drilled a hole in the stake pocket and put one nut as far down on the threads as possible, inserted the "stud" into the stake pocket and put another nut with a lockwasher on the back. In the rear, I drilled a 3 holes and put a corresponding "doubler" plate made from 1/8" strap. Nuts and lockwashers are used inside the stake pocket like the front. Base of the jack hangs on this stud and front part of the jack has a piece of mudflap that goes around the nut to keep the jack from banging into the stake pocket. You can see the little piece of rubber in the pic, it is sitting on the wheelwell in the closeup without the jack. An old drum brake retaining spring (not the tapered one), a washer and hair pin make up the rest of the mount. Total cash outlay, $3. Addin a little lock to the pin makes it theft proof as well.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 01-06-2003, 12:55 AM   #2
srhart71
Very nice low-buck, high enginuity tip. I think that will hold as well as if not better than the mounting kits that high-lift sells.
srhart71 is offline   Reply With Quote
Old 01-06-2003, 01:42 AM   #3
roger0080
That is darn near identical to what I have set up. Though I like how you mounted the base of the jack to the rear better.
In my setup I have a bolt mounted like you have on the center stake pocket and the rear. But I have to remove the base plate of the jack each time to mount mine up and attach the base everytime I want to use it. I used a big wing nut and a threaded handle (you know, you find this stuff in the pail of nuts and bolts you always have!) on the bolts instead of the cotter pin.
I have a bungee cord from the top of the handle down to the jack part to keep the handle from falling out.
Me thinks I will tweak my setup to match yours this spring.
Thanks for the scoop!
-Roger
72 Chev C-10 90% restored (former AZ truck) ...
71 Chev K-20 Cheyenne my vacation crusier...
72 Chev C-10 Now retired and striped after many faithful miles...
72 GMC 1500 Retired to the junk yard after bought new in '71...
roger0080 is offline   Reply With Quote
Old 01-06-2003, 01:46 AM   #4
basketcase
basketcase's Avatar
Very slick. Sure looks like it will get the job done.
Tom
'69 swb stepside in progress.
'59 Corvette lifetime project
basketcase is offline   Reply With Quote
Old 01-06-2003, 06:50 AM   #5
Lippyp
English Chevy Owner
Lippyp's Avatar
Thats a very neat and ingenious mounting set-up. My only comment on is that I would have mounted it on the passenger side to balance out the weight of the driver a bit!
I'm curious as I have a 5 foot high lift jack and locking mounting kit in the garage from my old LandRover. I can jack the back of my truck up by the rear step bumper (very solid). Where (and I pick my words carefully!) do you place the jack at the front of the vehicle?. I have a 67 2wd and just wonder if I could use the high lift rather than the little bottle jack I carry at the moment.
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
Old 01-06-2003, 09:53 AM   #6
Mike C
Mike C's Avatar
Good question. I use my stock jack when changing a flat. I keep the high lift as a utility for lifting, winching, and stretching. The only way I'd use it on the front bumper was in an emergency unless I could help it. I mounted it on the drivers side because of the up/down lever would be more out of the way turned to the inside. I have the Hi-Lift spring clamp on the handle as well as an old heavy duty inner tube from my mountain bike. That way the handle doesn't rattle. The hair pin serves the dual purpose of clamping the jack body and it also keeps the handle in line with the jack. I was originally going to go with the wing nut, but it might loosen from vibration while the pin/spring setup will not. I also would have had to add another component to keep the handle in line as well. Thanks for the compliments.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 01-06-2003, 10:59 AM   #7
Yukon Jack
Post Whore
Yukon Jack's Avatar
Looks great. I need to get a high lift and then decide if I want to mount it on the flatbed or the new front bumper that I'm gonna get at some point.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 01-06-2003, 12:49 PM   #8
Stout72
Not my good side.
Stout72's Avatar
Hey, thanks Mike C. That's where my jack is going. Great idea!
72 Chevy K20 Custom Camper, 350/350, 4" lift, dual shock suspension front & rear. Daily driver and a work in progress.
00 Suburban LT
90 Camaro RS
79 Yamaha XS1100 Special (Ol' Reliable)
Stout72 is offline   Reply With Quote
Old 01-06-2003, 01:56 PM   #9
Fred T
Cantankerous Geezer
Fred T's Avatar
Now y'all made that danged jack hard to use. any good ol boy knows you jest throw the jack in the back uf that truck!
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
