![]() ![]() Has anybody installed this and do you have pics of the install and after pics??? does it work with an under bed tank, any other problems springs or bags?? i think i want to go bags here is the link>>>> http://http://www.classicperform.com...ionPackage.htm
LIVE TO RACE!! DIE TO WIN!!! ![]() |
Never Ending Projects
Re: CCP's Complete Rear Suspension Kit with Coolride
Not sure what the big deal is with this setup. Outside of the crossmember giving a little more ground clearance, everything else is basically like the stock setup.
Basically add lowering block and a bolt in notch kit to the stock suspension and you end up with the same thing. You could add the dropped crossmember too and then put bags in the stock location. Not really seeing the benefit unless you want to make your wallet lighter. My .02 worth.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
anybody have pics?
?Anything??
