I have a saganaw (i think that is how you spell it) 3 speed out of some sort of pointiac i think. My question by any chance is this the tranny that came in the 67-72 trucks and if not will it work?
1969 ![]() 1972 ![]() |
![]() Join Date: Jul 2004
Re: Saginaw 3 speed
GM started using the Saginaw 3 spd in 1968, earlier likely had a very weak non-synchro low trans.
The basic Pontiac trans should be the same as the trucks, however, the trucks started using a 5 1/8 front bearing retainer where it fits the bellhousing in 1968, while the cars stayed with the earlier 4 11/16 size hole, so you may need to swap the front bearing retainer, (with a new gasket and seal) to match the bellhousing hole. Also, the truck trannys had threaded bolt holes for the bottom 2 bolts, cars just have holes, so you will need a bolt and nut inside the bellhousing to secure the bottom of the trans. Unless GM did something with the trans length or output shaft spline count, it should work.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
