07-06-2009, 12:52 AM | #1 |
Engine runs hot at idle and low speeds
Gentlemen,
My 1975 Chevy 350 small block seems to run hot all the way up to 210*when at low speeds and idle. it seems to stay around there if i keep the heat on but I'm afraid then engine might get damaged. I've recently changed the oil and oil filter. The thermostat is 180* and is around a year old. I had no such trouble last summer, what could it be? How do you know when your water pump is shot. Thanks for helpin a newby tryin o teach himself the ropes, Perry |
07-06-2009, 12:57 AM | #2 |
What?
Re: Engine runs hot at idle and low speeds
Are you runnin a clutch fan?
Chris 1968 K20 Suburban 1972 K10 LWB PU |
07-06-2009, 12:59 AM | #3 |
The front of it will wobble and/or it pees water out of a hole in the front of it.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
07-06-2009, 02:32 AM | #4 |
Big Red - Now its a SWB!
usually a low speed problem has to do with insuficient cooling in the ratiator. This could be from a clogged radiator or from a fan problem. Do you have a clutch fan? If so I would check out the clutch, when the engine is hot you should hear the fan moving air when you rev the engine. Other things that might be wrong is no shroud or incorect fan. Hope this gives you some ideas.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread 41 3/4 ton (wife's)-flatbed, fully restored to original 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
07-06-2009, 06:23 AM | #5 |
overheating at idle or low speed stop n go USUALLY indicates insufficient flow of air over the radiator, or some radiator passages are are clogged or too small a radiator (particularly when it works fine on the freeway).
it can (unlikely) be a symptom of a water pump impeller that is corroded away or clogged with mineral build up, which reduces flow... generally though in that situation you will have problems at speed as well. |
07-06-2009, 08:56 AM | #6 |
One of the First
Make sure you have the correct thermostat in the waterneck. I was running a 160 deg, same problem. Check the manual and installed a 180 deg. Solved the problem.
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
07-06-2009, 09:55 AM | #7 |
In my experience, the guys above are mostly on the right track, except D.Passmore (you've already stated you have a 180° T-stat). One thing that has NOT been mentioned is the flow through the engine block itself. I had this problem on a Chevelle years ago. I had to radiator cleaned/rotted out, but the biggest part of the problem was that the block needed to be back flushed. This is something a good radiator shop can do for less than $100. They do just what it implies: they BLAST water backwards through the block and remove any build up, etc. Do yourself a favor and look into this. If it isn't a failing water pump, I'll bet this helps your problem.
KEEP US POSTED! We'd love to know what the problem and solution is! |
07-06-2009, 12:26 PM | #8 |
HEy Thanks a lot Fellas.
I'm gunna get on it toniht and report any success. One thing though, May seem like a stupid question but, How do I know if I have a clutch fan. I have never seen the fan not spinning, does that mean anything? thank you kindly, Perry Last edited by retro dreamer; 07-06-2009 at 12:30 PM. |
07-06-2009, 12:38 PM | #9 |
woodman13
Common problem IMO could be the following:
Air in cooling system bad Water pump (can be bad and not leak or wobble just lack of antifreeze over time will eat the impeller off the shaft and decrease water flow. Lack of correct/missing shroud or fan. Lack of antifreeze (I use water wetter for 10 degree average drop in temp). Need more info on your system to come up with a better fix. How about a pic of your fan/shroud/water pump set up? |
07-06-2009, 01:33 PM | #10 |
WITH THE ENGINE OFF, reach in and try to turn the fan. If it turns, then you have a fan clutch. If it will only turn if the pump turns, then you don't. This really should have no bearing on low speed/idle overheating problems. Clutch fans lock up under about 1200 RPM (yes I know, this can vary).
03-03-2019, 09:49 PM | #11 |
I have 1969 C10, 350 SBC. Truck has been overheating to 210 when sitting idle or just drifting speeds. I've replaced the radiator, replaced the thermostat with a 160*. Truck still gets hot. I've been told that maybe it just idles too slow and to adjust. When driving normal speeds it cools down so I DO believe it's a matter of air flow over the radiator. I purchased a few water pump but seems like a 'last resort'. I'll make sure shroud is sealed off well and maybe adjust idle.
Any other ideas? |
03-03-2019, 10:14 PM | #12 |
Is the fan connected directly to the water pump pulley, or is there a finned aluminum part between the fan and the pulley? It would probably be 8 or 9 inches in diameter.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
03-03-2019, 11:10 PM | #13 | |
20' Daredevil (Ret)
I think you're on the right track as to air flow and having a good shroud. What kind of fan do you have? A fixed-blade fan can cause your problem, and a functioning fan clutch with a 6-blade or better yet a 7-blade fan should fix it. The fan should sit right at the end of the shroud, roughly 1/2 way inside the end of it. Pics would help....
03-04-2019, 01:20 PM | #14 |
Do you have a fan shrout?
that really helps. Mark
My build page http://67-72chevytrucks.com/vboard/s...d.php?t=764662 My cabinet building site http://www.cbcabinets.com |
03-04-2019, 08:13 PM | #15 |
Idle and low speed running hotter is almost always air flow thru the radiator. If the radiator or block were plugged it would also run hotter under a load, since the engine is generating more heat to dissipate. Years ago I had a fan clutch go bad and while the engine was running, I could actually grab the fan blade and spin it backwards. (Don't try this at home as your mileage may vary, years ago I wasn't as cautious as today)
Just recently I had a water pump explode and take out my fan and shroud. New pump, and fan blades without the shroud the temp would climb at an idle, as soon as I was moving it cooled right down. Replaced the shroud and all was good again. BTW: Never leave out the little pilot spacer when mounting the fan clutch to the water pump. At 5K rpm it may explode the water pump. Went thru 2 before I figured it out.
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
