07-06-2009, 07:45 AM | #1 |
Master and booster for disks?????
For the 67-72 trucks, what are you guys running that have 4wheel disks for the master and the booster. I have alwasys used the original master and booster that came on the 67 that had all drums but about every three years or so the rear seal in the master starts leaking. I would like to upgrade. The truck stops great using the old set up.
07-06-2009, 07:40 PM | #2 |
Re: Master and booster for disks?????
on my 82 i went to a factory hydro-boost setup for disc/drum
1949 Five Window, 1973 Step Side, 2000 Z71 |
07-06-2009, 11:33 PM | #3 |
60-66 Nut
I don't have an answer to the master cylinder problem, but if you want to try a different vacuum booster or a hydroboost, I have the brackets to make that happen.
http://www.67-72chevytrucks.com/vboa...d.php?t=347484 http://www.67-72chevytrucks.com/vboa...d.php?t=347480
