Old 07-06-2009, 11:47 AM   #1
71C10SWB
71C10SWB's Avatar
Question Anybody running rear load leveling bags in coils?
I have some light springs (not C/10, Jeep TJ) in the rear of my 71 C/10. I would like to be able to tow my trailer or carry a load every now and then. I was thinking I would like to run a set of the rear AirLift bags in my rear coils for load carrying purposes.
I found a part number listed in summit's catalog, but no pictures.
I went on to Air Lift's web site and they don't list anything for the truck.
I know I should probably run lowered rear C/10 coils, but I'm on a budget here.
Is anyone on here running bags in their rear springs?
Any pictures?
How's the load carrying?
71C10SWB is offline   Reply With Quote
Old 07-06-2009, 02:00 PM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: Anybody running rear load leveling bags in coils?
That's my plan. I know Air Lift doesn't have a specific bag for the C10 springs. I figured ones for a Chevelle/El Camino would work fine, I think part # 60733 is for the El Camino. Their springs are about the same diameter as C10 springs.
Not sure if the TJ springs are similar in diameter but I bet those would work. This stuff is fairl basic. Air Lift claims 1000# capacity of those bags.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 07-06-2009, 04:15 PM   #3
67dragtruck
67dragtruck's Avatar
Yes they do and I have run them with success.
Tom
No more dragtruck for me. I'm building a new ride though. It's a '71 fleetside, 400 sbc, 700R4. Working on it now, finally. Soon to have Edelbrock Pro Flo EFI, Vintage Air, 1 piece windows, buddy buckets, etc.
My new build thread:
http://67-72chevytrucks.com/vboard/s...17#post2861817
Best pass with the old dragtruck:
5.32 @ 131.6 mph 1/8 mile w/ a 1.25 60' Fogger/Plate 2003
Best pass with the street 406 hydraulic roller motor w/ mild plate tuneup
5.93 @ 114 mph 1/8 mile w/ a 1.29 60' 2003 or 2004
67dragtruck is offline   Reply With Quote
Old 07-06-2009, 05:10 PM   #4
69GMCLonghorn
69GMCLonghorn's Avatar
Nope... I have rear springs rated somewhere around 9000 - 10,000 lbs. If I need to bag it, I'm doing something I shouldn't be doing with a 40 year old truck!
I've heard good things about bags on the 1/2 ton trucks... Good luck!
69GMCLonghorn is offline   Reply With Quote
Old 07-06-2009, 05:22 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
i have them in the back of the suburban, got the ones you are talking about. I had to call them up and get some rubber spacers, and then modify them a bit, but it was all quite painless... even calling the lady to get the added parts.
They work great. The lowering springs on the back of my suburban are 4 inch drop truck springs... that made about a 6 or 7 inch drop... I couldn't run over a pebble without the axle slamming into the frame. No problems at all now.
However, you mentioned budget... by the time you get the bags, and the added parts, you could very well have bought better springs.
On the flip side, these are adjustable from low to stock height.
Old 07-06-2009, 05:22 PM   #6
chevy_mike
chevy_mike's Avatar
Tom
When you say "Yes they do" do you mean they have a set for coil sprung C10's? I wasn't able to find a part number on their site.
Old 07-06-2009, 09:01 PM   #7
1970bowtie
1970bowtie's Avatar
i have a set for the el camino, i was afraid to install them because of the bolt that comes threw the bottom of the trailing arm into the spring, no one has any problems with this rupturing the bag? also what did you do with the air line running to the bag? did you drill a hole in the frame rail or what? info would be appreciated, i have ss chevelle springs already installed in the rear and was wanting to bags to stiffen things up some
Justin
1970 c/10 short wide bed
WTT 1970 chevy front end for 67/68 chevy front end
WTT 2 15x10 american racing outlaw 2 wheels for 2 of the same in a 15x7 or 15x8
1970bowtie is offline   Reply With Quote
Old 07-06-2009, 09:58 PM   #8
Longhorn Man
you'll have to call the company and order some rubber spacers, then drill a hole in it for the line.
Old 07-06-2009, 11:19 PM   #9
1970bowtie
1970bowtie's Avatar
well i have the spacers from the elcamino but there only bout a half inch thick, youu dont happen to have any pics of your set up do you?
Justin
Old 07-07-2009, 09:34 AM   #10
Andy4639
Old member
Andy4639's Avatar
Here are the bags I used and I think Longhorn Man used. We PM'ed each other on this before. I love them. My 71 has the lowered back springs and it rode like crap before now it has a nice floating ride.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 07-07-2009, 04:20 PM   #11
Longhorn Man
you see andy had to install the specers above, and below the bag.
I also chopped off the eposed bolt that pokes up through the center of the coil on the bottom, where the hold down to the trailing arm is. look in your coil, you'll see what I am talking about.
Old 07-09-2009, 08:12 PM   #12
1970bowtie
1970bowtie's Avatar
ok thanks for the pics is there anywhere i can go to get the spacers, any suggestion on what i could make them out of? i want to avoid orderin them if i can
Justin
Old 07-09-2009, 09:41 PM   #13
lts70
1970 Daily Driver
lts70's Avatar
I have 4" lowering springs from CPP and am not impressed. I was thinking about doing this mod as well. Is there benefits in running the leveling bags in the springs over running a couple actual air bags off of a shrader valve?
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance.
lts70 is offline   Reply With Quote
