Old 07-06-2009, 11:50 AM   #1
FLDBRED
Metal upper radiator hose?
My 71 has the metal upper radiator hose!Does anyone know why Chevy did this?Should I keep this or go to an all rubber hose?Thank You!
FLDBRED is offline   Reply With Quote
Old 07-06-2009, 12:13 PM   #2
combustion
Re: Metal upper radiator hose?
pics?
If it`s 3.73 ratio you will spint the wheel 100 times to the driveshaft`s 373 times.Or,if you`re lazy,you could just spin the wheel once and the driveshaft will spin 3.73 times.Or, 3 and 3/4 turns.And if you`re real lazy,I can sell you a tab for whatever ratio you want.
Or,you could read all the suggestions and try those.It`s been well explained,I think,already.
combustion is offline   Reply With Quote
Old 07-06-2009, 12:54 PM   #3
mrein3
mrein3's Avatar
Mine does too. In fact I think all the 4x4s had that from the factory.
Not sure why.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 07-06-2009, 02:05 PM   #4
turp mcspray
turp mcspray's Avatar
I believe this is how all 4wd came. Not sure if it was because of the length or something else. I have always used them on my trucks.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 07-06-2009, 02:33 PM   #5
morgan71
Ive read that it came factory in 4wd's because of low gears, low range transfer case, could cause engine to run hotter which could cause upper radiator hose to swell and burst. I would keep it , if its in good shape.
morgan71 is offline   Reply With Quote
Old 07-06-2009, 02:58 PM   #6
vectorit
What?
vectorit's Avatar
Here is mine.
It's off right now, since it is rotted out pretty bad.
I have been searching for shops that can bend pipe to duplicate mine, but no dice yet since it has too tight of bends that most bending machines can't duplicate. (At least in my neck of the woods).
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 07-06-2009, 03:00 PM   #7
msgross
msgross's Avatar
I just bought one to put on my 68 K-10... I want it for the originality..
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 07-06-2009, 04:05 PM   #8
turp mcspray
I would think finding a used one would be fairly easy to do. If you need one I'm sure a board member has an extra.
Turp Mcspray
Old 07-06-2009, 05:31 PM   #9
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Originally Posted by vectorit View Post
Here is mine.
Looking at the picture, I would think any exhaust shop should be able to take care of that. I had that done on a kit car I was building, for the gas filler cap to the fuel cell. Made kind of an S bend.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 07-06-2009, 05:43 PM   #10
68,69 K20
They call me the Breeze...
68,69 K20's Avatar
Here is your tube in it's first home...
I believe the metal tube was used on 4wd's only...
Mike
69 K20
"Beer is proof God loves us and wants us to be happy"....Ben Franklin
68,69 K20 is offline   Reply With Quote
Old 07-06-2009, 07:14 PM   #11
FLDBRED
Thanks Guy's for the input!I think I'll keep it,if it is not rusting on the inside.
Old 07-06-2009, 07:22 PM   #12
msgross
msgross's Avatar
and if it is rusted then soak it in a chemical rust remover... then have it powdercoated (if that resists antifreeze!) or some other type of coating.
The Garage:
Old 07-06-2009, 07:56 PM   #13
chipflyer
chipflyer's Avatar
It was a 4 wheel drive only thing. The engine is set back closer to the firewall by quite a little bit on them to provide more clearance between the oil pan and front axle. Its also why they have a different/longer fan shroud.
Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen.
1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets!
1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241.
chipflyer is offline   Reply With Quote
Old 07-06-2009, 07:56 PM   #14
Skirkpat
Skirkpat's Avatar
Well I guess I should use the one I have on my 4x4 Burban, I thought it was a Redneck engineered deal on my 69 3/4 ton truck I parted out.
1969 Short Stepside
1969 4 WD Suburban
1970 1 Ton Dually....Misfit
oh, and a 2001 HD 2500, 8.1 Allison Shortbed 4 Door
Skirkpat is offline   Reply With Quote
Old 07-06-2009, 10:13 PM   #15
pritch
pritch's Avatar
I always thought it was a GMC thing. Maybe GMC 4X4's only?
'68 Panel
Project Boogie Chillin'
'68 C-10
Ol' Green
pritch is offline   Reply With Quote
Old 07-06-2009, 10:22 PM   #16
jerry moss
Born Psycho
jerry moss's Avatar
all 4x4s of 67-72 vintage had them, chevy or gmc. it's not a simple thing to bend on a muffler shop bender, i've got 25 years experience at the same shop. i bent a few out of stainless and got them really close but not exact, the two bends closest to the engine don't come out quite right. i still have them somewhere and never finished the ends to see if they would actually function as the oem version did.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is online now   Reply With Quote
