Watchin the rust grow
![]() Join Date: Oct 2008
Heater Core Question and a Turn Signal Question
I was wondering if someone had any idea how tough it is to change out heater cores on a 79 K10? No AC.
The real question. When I click my left turn signal on, the indicator just stays lit green, it does not blink, but if I just hold it down and then let it up it will blink normally. Occasionally it will blink as it is supposed to, any ideas where to start? Thanks.
1979 Chevy K10 (H/D Front end) - 350 w/ Holley Truck Avenger, Weinald Intake manifold, headers, bored .060 over, mild cam, Built up TH350 (TranStar Shift kit) with a part-timed NP203 t-case SOLD ($3,000) 1997 Chevy Silverado 1500 - 4.3 vortec, extended cab, 21 highway MPG, stock. "Red" SOLD ($3,000) 1987 Toyota 4wd Pick-up - work in progress, future DD SOLD ($1,850) 1998 Dodge Ram 2500 Cummins 5spd Quad cab - old 12 valve with some work done ![]() 2004 Chevy Silverado - Black, 4x4, 5.3L, stock for now Underneath that rust is a heart of gold
Gen III Power
Re: Heater Core Question and a Turn Signal Question
My 81' with A/C took about 2.5 hours to do the heater core. And that was the first time I had ever done one. Not to hard at all.
For the blinker I would start with checking all your bulbs, you may have one out. And then check the turn signal flasher on the fuse block.
---Bob--- '81 Long Box. 2005 5.3l Vortec and 2005 4L80e coming soon... |
The heater core is not that bad at all to replace. As for your turn signal problem, it sounds like you have a faulty turn signal switch which is mounted beneath the steering wheel. This to is easy to replace once you get the steering wheel off and have a compressor tool to comp[ress the plate. If you turn on your emergency flashers and they flash without a problem, then the problem is most definitely in the turn signal switch.
Robert Olson Transport
![]() Join Date: Oct 2002
if you go to a chain auto parts store like autozone they can print out step by step instructions on how to do the heater core and the turn signal switch as long as you buy the parts from them.
The heater core isnt so bad on a non ac truck and the turn signal switch is easy too just make sure you have the proper tool to remove the lock ring under the steering wheel
