"Oil Canning" Hood
Anyone have the problem w/your hood "oil canning"? You know, vibrating when you hit a bump. My 67 hood has no insulation in her like a new truck. What have you done to put an end to the vibration?
Raymo |
Re: "Oil Canning" Hood
I cut one of the braces out a doner hood and add a third in the center, matches and looks oem to the untrained eye.
its all about the +6 inches
there's supposed to be material between the ribbing and the sheet metal, keeps this to a minimum.
What kind of material? All that's in mine is what looks like small pcs. of a cardboard box.
Raymo |
Sisyphus was my mentor!
![]() Join Date: Sep 2002
The material is a type of roughly 3/8" thick spongy rubber.
passthebuck ![]() #5642 -TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4. -a 2013 Honda Civic as my "sensible" car |
Also don't overlook the hood hinges. Make sure the hood hinges are well lubricated so the hood opens easy and smooth. I've seen hoods bend in the middle when they were kind of "forced" open due to rusted or nearly frozen hinges. Repeated opening a hood with stiff hinges will permanently cause that "brokeback" bow in the middle of the hood.
what i did was removed the factory foam and used a tube of urathane to squeeze in between the hood and the hood support. it's a 3/8 inch by 3/8 of an inch on both sides of the two hood braces. then smoothed it out nice when it was still wet. it's been there since 1984 when i restored my truck and no problems since.
Trueman |
i also use fluid film on all the moveing points. that's two fingers to lift the hood. link:http://www.sp3sales.com/fluidfilmaerosolspray.aspx
Trueman |
Just go on to LMC Truck.com. They have the insulation kits for about $30 I think. I bought a set when I did my truck and it made a world of difference!
Thanks everyone! Some great ideas.
Raymo |
Yep -- my truck had none, it resulted in heavy waving and rippling of the hood when driving. I robbed some of these spongy rubber strips, wedged them in place, and about 95% of the flexing is gone. Good enough for me ![]() |
The Red Menace
So the insulation (only $12 from LMC by the way) will cut down on the hood vibrating? Mine only does it when I'm stopped in gear. Park or neutral or when I'm moving is ok, but at lights and stop signs it vibrates a lot!
1971 Custom 10 - 350/350TH - Pwr steering, gauges, Chrome front bumper, Chrome hubcaps, Door edge guards, HD rear springs (current) 1968 C-20 Custom Camper - 350/350TH (orig 327), Pwr steering & brakes, gauges w/tach (former) 1968 C-20 - 307/3sp column (Dad's when I was a kid) "Driving is like coloring. Things get messy if you can't stay inside the lines." |
