Edelbrock 1406 and 700r4
Just bought a 1986 C10. I have an Edelbrock 1406 that I want to put on. I did a search and can't get all the answers I need. What brackets do I need to hook this carb up to the 700r4 with a stock manifold? Part numbers for Summit/Jegs would be very helpful. I want to do this right the first time. The Rochester carb on there right now is in bad shape. I will get some pics up later. Thanks for the help.
BAD BOW-Silverado XST
Re: Edelbrock 1406 and 700r4
Do you have cruise control?
You need this TV angle correction bracket. ![]() Buy it at www.jcwhitney.com it's cheaper than jegs or summit. Use Edelbrock's cable bracket if you don't have a stock cruise control setup. Edelbrock #350-8029 at www.jegs.com ![]() ![]() Last edited by gchemist; 07-06-2009 at 11:06 PM. |
Parts and more parts
For starters look at an Edelbrock catalog or parts book. You will need a cruise control/tranny bracket to allow for connecting your goodies to the truck. If you plan on keeping the "Stock" manifold, then you will have a little issue with the matching of the bore patterns without getting a transition plate from the "square-bore" to the "Spread-bore" design. You will also need to make sure that your 700R4 cable is operating right, due to the TV cable is different than a "Kick-down" cable like a TH350 has. Many people go to places that sell OD trannys for this---I built my own and mounted it to the rear carb mounting bolt and used the extra hole in the carb's left rear foot as a place to ensure the bracket stayed in on place. I welded a pin onto my bracket to fit into that hole.
Look up these Edelbrock numbers Cruise control bracket #1484 Quadrajet adapter plate #2696 Idle compensator solenoid #8059 Throttle and transmission kickdown bracket for 700 R4 #8036 |
Thanks for the replies. I do not have cruise control. So will that make a difference on what brackets I need?
Thanks. |
Once again, take a look at edelbrock's webstie under accessories and see what they offer. Calll their tech number and go from there. The cruise control bracket gave me everything that I needed and it is easy to hook up.
Thanks. Will look at the Edelbrock website tonight.
What size engine do you have? If it is a 305, why would you put a #1406 600 cfm verses the #1403 500 cfm which is what Edelbrock recommends. LMC recommends the 600 but I'm not sure I trust them. I bought some windows seals from them and they are the wrong ones. I was thinking I would replace my carb with the Edelbrock too.
#8 | |
As for LMC, they ARE a warehouse outlet, not a speed shop. I would go to an engine builder for further information on the needs of your engine, not a group of guys that are working a parts sales counter. With that in mind, the process at LMC is not without error--if you got the wrong seals, tell them and they will make it right. I have gone to their sales counter and they are good people. Last edited by piecesparts; 07-09-2009 at 09:14 AM. |
I have a 350 and am using a 1406 on it. I spoke with a tech at Edelbrock and he gave me the parts that I needed for the TV cable geometry bracket. Found at the door this afternoon.
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
I have a 1406 Edelbriock Carb on my 396 and I haven't touched it since 2001 when I bought the truck.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
hey luke what numbers did they give you and do you have any pics withthe stuff installed?
