Old 07-07-2009, 05:14 PM   #1
jmuck
jmuck's Avatar
Air ride on a Mustang II?
What type of airride set ups are you guys using on a MII frontend. I am going to bag a 1951 that already has a MII coil over shock on it. What would be the easiest way to bag it? Thanx for the help
jmuck is offline   Reply With Quote
Old 07-07-2009, 06:53 PM   #2
mylow53
mylow53's Avatar
Re: Air ride on a Mustang II?
have a look at my build. do you have any picts of your setup?
GT
http://67-72chevytrucks.com/vboard/s...d.php?t=215079
Greg
1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school
http://67-72chevytrucks.com/vboard/s...=215079&page=5
mylow53 is offline   Reply With Quote
Old 07-07-2009, 07:12 PM   #3
entourageguy
Yellow truck club
entourageguy's Avatar
I replaced my coil overs with a set of shockwaves. Had to relocate the upper mounts for the shockwaves to clear. Better check with the manufacturer of your set up. You might have to change some things as upper mounting will be different for the bags.
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
