07-07-2009, 06:16 PM | #1 |
power steering install
hey all,
I tried to install my powersteering setup on my new gm crate. It seems as the bracket setup will not work with a 8in balancer. my previous motor had a 7 in balancer. Any of you guys run into this problem and what was the soluton?........thanks rick
69 C10 LWB GM 350 crate motor, 3.73 rearend |
07-07-2009, 06:59 PM | #2 |
member #16
Re: power steering install
Does your new crate have a long water pump? If so you will need all the pulleys and brackets off of the old engine along with the short pump.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ Last edited by john; 07-07-2009 at 07:00 PM. |
07-07-2009, 07:15 PM | #3 |
no I have the short pump on the new motor. it seems that the 8 in balancer is interfering with the bottom pump bracket. I quess I could switch to a 7in balancer, but there should be a simpler solution.
07-07-2009, 08:06 PM | #4 |
is there a different bracket setup for use with a larger vibration damper? I would prefer to keep the larger damper installed.
07-07-2009, 08:25 PM | #5 |
You have a bracket for a small balancer. Just find the correct bracket for the large balancer. Shouldn't be too tough to do . Or you could buy a new bracket. If you want a new one and the truck catologs don't offer one go to Ground Up restoration parts. Find one for a 68 and older application with short water pump. I bought one there for my El Camino. Get the one listed for an L-79 327.They all had the large balancer with the short pump.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
07-07-2009, 10:46 PM | #6 |
thanks for the info Turp.....pulled a pic off of ground up website. does this look like the bracket i need........thanks for the help
69 C10 LWB GM 350 crate motor, 3.73 rearend Last edited by rick0312; 07-07-2009 at 10:46 PM. |
