Old 07-07-2009, 10:22 PM   #1
myfirstcarwasa73trk
myfirstcarwasa73trk's Avatar
Fitment problems
also got my 350 th350 in my 67 tried to use the x-member from the donor 85 but frame is smaller what are some cheap options I could go with? Is there a way of making it work?
myfirstcarwasa73trk is offline   Reply With Quote
Old 07-08-2009, 12:01 AM   #2
westofb
I really hate wet sanding!
westofb's Avatar
Re: Fitment problems
heavy piece of angle iron, drill some holes bolt it on.
westofb is offline   Reply With Quote
Old 07-09-2009, 06:04 AM   #3
GMCPaul
We sell a new style auto crossmember for $70.00 thats a direct bolt in.
http://www.gmcpauls.com/auto.transmission.htm
Part#653253
With the fact that the 73up frame is so much narrower than a 67-72 I myself wouldn't want to try to fabricate something to make the 73up crossmember work because you'll either need to weld brackets on the frame to extend it further in or to the crossmember and both would look rather hobbled up in my opinion considering what needs done to make it work.
GMCPaul
GMCPaul is offline   Reply With Quote
Old 07-09-2009, 08:58 AM   #4
VanceH
Loving the Jimmster
VanceH's Avatar
I puchased one from a member for 40.00
VanceH is offline   Reply With Quote
Old 07-09-2009, 09:02 AM   #5
VanceH
Loving the Jimmster
VanceH's Avatar
http://67-72chevytrucks.com/vboard/s...t=cross+member
