Old 07-07-2009, 10:24 PM   #1
JCA1972
JCA1972's Avatar
Whining noise, please help
I have a 71 c-10, I got it on the road last September and I noticed that it makes a whining noice when going between 30 and 50 mph. Kind of like WHaaaaaaaa. when I slow down it quits making the noise. I have changed out the transmission, u-joints and carrier bearing on the drive shaft, and it still makes the noise. I took it to a rear end place and they said that they didn't think it was the rear end and they couldn't tell me what it was. I'm hoping that some of you C-10 pros might have the answer. Thanks in advance.
1971 C-10
2004 Yukon:
1998 Honda Accord
2008 Honda Civic
2004 HD V-Rod
http://67-72chevytrucks.com/vboard/s...d.php?t=226458
JCA1972 is offline   Reply With Quote
Old 07-07-2009, 10:43 PM   #2
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
Re: Whining noice, please help
I had that exact same problem but I came to a complete stop and made my mother-in-law get out!!!!
That is one of those things that can be hard to diagnose without riding in it. I know you need to be on a lonely road for this one but maybe get someone in the bed when you are going down the road to see if they can figure what part of the drivetrain it might be coming from.
prostreetC-10 is offline   Reply With Quote
Old 07-07-2009, 10:59 PM   #3
Camper Power
Camper Power's Avatar
can you tell if the sound is coming from the front/back, on a particular side? my guess is it would be the wheel bearings.
eh
1970 Chevy C20 daily driver
1975 GMC Jimmy 4x4 project
1966 GMC C10 Dad's project
Camper Power is offline   Reply With Quote
Old 07-07-2009, 11:16 PM   #4
BAGNDRAGIT
Just Not Low Enough!
BAGNDRAGIT's Avatar
there are so many possibilites, i agree that you should try and find out exactly where to noise is on the truck. did you change your speedo cable when you changed the transmission?
NEED ELECTRICAL HELP? ASK ME!
67-72 Full Wiring Diagrams
Lots Of Info, TAKE A LOOK
1967 Chevy C-10 Shortbox Bagged 327 4spd
Previous:
1971 Chevy C-10 Short Sep I6 Auto (Traded)
1973 Chevy C-20 *THE REDNECK BATTLE TRUCK*
2001 Chevy Silverado 2Dr 5.3L Shortbox. R.I.P.
1969 Volkswagen Bug
This is my first meeting, I have a horsepower problem.
BAGNDRAGIT is offline   Reply With Quote
Old 07-08-2009, 08:37 AM   #5
68gmsee
Active Member
68gmsee's Avatar
As has been mentioned, the first thing you need to do is isolate it to a certain area: front, rear, middle, etc.
Does it change pitch if you let off on the gas pedal or is it pretty much constant? Rear end and other drive train noises sometimes manifest themselves as you incease speed and diminish when you let off on the pedal.
Whining noises can come from many different areas including the ones you've already checked. I have a wawawawa noise right now that is coming from one of my front tires. Been doing it for a while and I know it's a bad tire (threw a belt).
68gmsee is offline   Reply With Quote
Old 07-08-2009, 01:21 PM   #6
JCA1972
JCA1972's Avatar
From inside the truck the noise sounds to be in the center of the truck. Thats whey the rearend guy said that he didn't think it was the rearend.
The front wheels have new bearings in them and I changed the oil in the rearend.
I didn't change the speedo cable, could that be it?
The noise changes from a low pitch to a high pitch.
I'm goint to raise the truck and have someone accelerate while I monitor the bottom of the truck. (scarry)
1971 C-10
2004 Yukon:
1998 Honda Accord
2008 Honda Civic
2004 HD V-Rod
Old 07-08-2009, 07:01 PM   #7
68gmsee
Active Member
68gmsee's Avatar
Originally Posted by JCA1972 View Post
...........I didn't change the speedo cable, could that be it?
You can try relubing the speedo cable. On my 68 I can yank it out of the sheath... Only thing is I don't remember if I can do it from the top or the bottom or both.
As for raising the truck to run it; I've done that before but you have to make sure it's blocked and on jack stands. The other thing is that without any resistance on the tires, they will spin like crazy. Try using the brakes or even the parking brake as you give it gas to see if you can create some sort of resistance if you don't hear any whining.
Old 07-08-2009, 07:31 PM   #8
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Don't forget tires.I have had tires make some crazy noises and while driving things can "Ventriloquize"(is that a word or did I just invent it?) or seem like they're coming from somewhere else.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
