Old 07-08-2009, 12:28 AM   #1
demon79
demon79's Avatar
1960-66 dually
i have a 64' c-30 i'm planning to build into a dually i want to build a dually bed that looks stock i was wandering if anyone has done this and if so do they have any pic they could post thanks
demon79 is offline   Reply With Quote
Old 07-08-2009, 01:57 PM   #2
RunninLo
3DrDwn--the 'burb not the band
RunninLo's Avatar
Re: 1960-66 dually
i haven't seen a 60-66 but i know of a 67-72 style that used a long fleet bed with stepside fenders for the dually fenders. i think this would be a good period correct look.
I know JonZ has toyed with this idea and if you search i know he has posted some 60-66 dually renderings
Josh
Slo and Lo that is the tempo.
'72 burb build page here:
http://67-72chevytrucks.com/vboard/s...d.php?t=259256
'89 GMC Dually crew build page coming soon.
88 4x4 crew DD
duallys past/present pics here:
http://67-72chevytrucks.com/vboard/s...46#post4001246
89 1 ton Dually rear flip kit install here:
http://67-72chevytrucks.com/vboard/s...d.php?t=354327
RunninLo is offline   Reply With Quote
Old 07-08-2009, 09:02 PM   #3
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: 1960-66 dually
here is a photo chop that I found:
Old 07-08-2009, 09:14 PM   #4
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: 1960-66 dually
I've seen it done with steel stepside fenders and fiberglass stepside fenders. Takes talent to work the steel one's , but the effect, WoW!
Old 07-08-2009, 11:52 PM   #5
Captainfab
60-66 Nut
Re: 1960-66 dually
I think the stepside fenders would be the way to go, but IMO they would need to be sectioned to look right. Like aerotruk63 said, it takes talent to do it, but the end result would be worth it.
Old 07-09-2009, 01:30 AM   #6
newagecustom
c10 Chop Artist
newagecustom's Avatar
Re: 1960-66 dually
I had a rendering of a standard cab dually that used the stepside fenders, it really looked like it belonged that way. I dont know where the rendering went, otherwise i would post it.
newagecustom is offline   Reply With Quote
Old 07-13-2009, 10:52 PM   #7
Ghostwhite
Squarebody guy
Ghostwhite's Avatar
Re: 1960-66 dually
Went to a freaky f'd up wedding 4 hours from home but found this next to an old warehouse. No info on it what so ever!!! C30 i believe
Ghostwhite is offline   Reply With Quote
Old 07-13-2009, 11:37 PM   #8
Captainfab
60-66 Nut
Re: 1960-66 dually
That is really interesting. Whoever widened that bed did a good job. I'm assuming there had to be wheelwells inside the bed?
Old 07-14-2009, 05:50 AM   #9
aerotruk63
aerotruk63's Avatar
Re: 1960-66 dually
The tailgate looks similar to this one. This is a Argentinian built model 1964-66. They were all built Panoramic View back glass.
Old 07-14-2009, 05:53 AM   #10
aerotruk63
aerotruk63's Avatar
Re: 1960-66 dually
Would the stock fleetside front panel bolt right up to the stepside bed side panels ?
Old 07-15-2009, 12:02 AM   #11
chevytrucknut
chevytrucknut's Avatar
Re: 1960-66 dually
I would like to see more of this truck. Do you have more pics?
I have seen the step side style bed on a dually before but it was a '57. it looked cool with fleetside inner fender wells.
I also have seen a factory dually that just had a sheetmetal flare under the rear wheel well. The truck was a '61 GMC 3/4 ton 4x4 and had dual adapters. It looked really cool too.
'77 GMC SWB
'66 SNB (Project)
Battle Ground, WA
chevytrucknut is offline   Reply With Quote
Old 07-15-2009, 12:12 AM   #12
Captainfab
60-66 Nut
Re: 1960-66 dually
That's interesting looking. I see it has a latch on each side of the tailgate, and different taillight and BU light setup.....so this is original for an Argentinian truck?
Old 07-15-2009, 05:39 AM   #13
aerotruk63
aerotruk63's Avatar
Re: 1960-66 dually
Found this thread in the Internaional region and chapters thread. Have been posting on this site for information. Google translator helps alot.
http://www.chevynet.com.ar/
Old 07-17-2009, 11:40 PM   #14
blackedoutharley
Re: 1960-66 dually
Rich Guasco of "Pure Hell" fame (AA/Fuel Altered) had a '60-'66 dually that used a late 80's - early 90's dually bed.
As I recall it had an injected 502 with an auto of some sorts. P/S, A/C, P/Seats, tilt etc... was very nicely done.
They even molded the body line from the later bed into the cab corners for a finished look.
You may be able to get info or pics from him.
I believe the website is www.purehellracing.com
blackedoutharley is offline   Reply With Quote
