Old 07-08-2009, 08:50 AM   #1
MANDO
MANDO's Avatar
Ac problem with my 1972 chevy truck
My ac blows cold air when i have it parked but when you start driving i get hot air coming out the vents when i stop at a light it starts blowing cold air again has anybody had this problem before
MANDO is offline   Reply With Quote
Old 07-08-2009, 08:56 AM   #2
JohnC
JohnC's Avatar
Re: Ac problem with my 1972 chevy truck
Sounds like maybe flapper door isn't closing or something. Hopefully someone will have more info on it.
JohnC is offline   Reply With Quote
Old 07-08-2009, 08:58 AM   #3
MANDO
MANDO's Avatar
Do you know where the flapper door is located
Old 07-08-2009, 09:01 AM   #4
JohnC
JohnC's Avatar
Sorry I don't. I'm not familair with the 67-72 trucks. I'm sure someone will chime in and help you out with more info. This site is full of great info.
Also I forgot earlier. Welcome to the boards!
Old 07-08-2009, 09:04 AM   #5
MANDO
MANDO's Avatar
ok thanks
Old 07-08-2009, 09:05 AM   #6
Ricks1971
Ricks1971's Avatar
The flapper door is located under the cowl on the passenger side just under the pass side wiper.
Ricks1971 is offline   Reply With Quote
Old 07-08-2009, 09:08 AM   #7
markster5
sound.s like a vacuume problem check to see if youre vac canaster is holdind vacuume.and check the hot water valve to see if it is closing all the way. ir vacuume is lost the system will defalr to defroster.
markster5 is offline   Reply With Quote
Old 07-08-2009, 09:10 AM   #8
MANDO
MANDO's Avatar
Ok i will check when i get home to see if that is the problem
Thank You
Old 07-08-2009, 03:59 PM   #9
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I agree with the Vac problem... however, these trucks won't defult to the defroster vents. Those doors and flappers are all manual on these.
