Active Member
![]() Join Date: Nov 2002
WTB three speed cross member
Looking for a three speed cross member. Is this the same as the auto cross member? Would like to see a picture of the three speed cross member so I know what I am looking for.
Thanks Don Brace MN
Don Brace 55 Nomad 56 Nomad 58 Impalla Coupe 58 Bel-Aire 4D HT 61 Impala CVRT 409 4 SP 2- 71 Longhorns Always looking for old toy trains, Juke boxes Pin ball and game machines. |
#2 | |
Is it done yet?
Re: WTB three speed cross member
From what I know the Auto trans is the only trans that needs a cross member. The Manual trans dosent. I may be wrong. Hope that helps. Brian.
1972 Chevy SWB New 383 Stroker/350 Turbo Some day i'll paint it John 3:16 MY BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=398108 Last edited by Southern C10; 07-08-2009 at 09:55 AM. |
Member #1049
Don,
The picture in Prathbun's post is a good representation of what you are looking for.. The manual trans mount is technically a crossmember that is riveted to the frame. One thing you need to look out for is Chevrolet used two different versions, (not sure about GMC's) a 6 cylinder one and a V8 one,, they look almost identical unless side by side.. the V8 one sits farther forward than the 6 cylinder one.. Sorry I can not help with any pics.. |
Active Member
Livrat
Thanks for the information. I am going to the IOLA Wi swap meet today and will look for one. Looks like the one in Prathbun's photo mounts under the bell housing. Is there one that goes under the trans mission? Thanks Don Brace MN
#5 | |||
Union Electrician
I have two here camne get a pic later, but $10 plus shipping for eithr one, I am not sure if they are 6 or 8 as stated above. I do know they are for a standard tranny. SHipping would be 20 or less I would guess...Randy
![]() ![]() Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
Active Member
Randy
Are the two you have the same or are they different from one another? I am off to IOLA WI car swap meet and will get back to you on Saturday. My guess is the only difference between the six and eight cross member is the mounting holes which is no big deal. I looked under my truck and there are two sets of holes to mount the cross member. Thanks Don
No, not with standard transmissions. Automatics only.
Wynne 70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s. Build thread 53 Chevy shortbed 69 Camaro Click here to subscribe Chevy GMC International Truck Club Louisiana Charter Member http://www.louisianaclassictruckclub.com |
Is it done yet?
I learn something new here everyday!!
1972 Chevy SWB New 383 Stroker/350 Turbo Some day i'll paint it John 3:16 MY BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=398108 |
#9 | |||
Union Electrician
Yep I am purty sure not under the tranny, just the bell housing
Active Member
Currently I have an automatic crosss member under my 3 speed overdrive and none under the bell housing. I have lots of clutch chatter and think that not having the member under the bell housing maybe part of the problem.
Thanks for the replies. Don MN
#11 | |||
Union Electrician
pics of manual x-member
Member #1049
Don..
from the factory all the trucks used one under the belhousing.. GM cars used one under the trans, if you have the surface on the tailshaft of your trans for a mount you can use the stock truck automatic crossmember. |
#13 |
Member #1049
oops, replied to your original post before I saw this one..
If you have alot of clutch chatter it is more than likely for some other reason than the rear mounted crossmember... probably either a warped flywheel, bad clutch disc.. pilot bearing worn out.. bad input bearing in the trans etc.. |
#14 |
Active Member
I'll check on the clutch and the pilot bearing and let you know.
Thanks Don
#15 |
Roadtrip!
![]() Join Date: Feb 2003
Don, did you find your parts at iola? If not, i will see if i have something here on a parts truck if you still need it. Eric
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
#16 |
Active Member
Eric
I am still looking for the three speed cross member and the inner passenger side rear bumper bracket. Also trying to figure out why my power steering pump is so close to the alternator bracket that I cannot get the P/S cap off. Don
