Old 07-08-2009, 10:41 AM   #1
COACHMEASON
Keep On Keepin' On
COACHMEASON's Avatar
Ball joints and drop spindles...
I have the Belltech 3in drop spindles...As I start reading the instructions its one of those "modify" projects which is fine. I am going to change out my ball joints since I am there...Question...Should I stick with the 72 ball joint or get a later model ball joint?? Thanks
07 Avalanche Z71
92 Mustang 5.0 GT (Triple White w/ 53,000 miles)
72 SWB Chevy w/ PS, AC, 350/350
Current Project ....In paint shop getting body/paint work done (Corvette Velocity Yellow)...
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
COACHMEASON is offline   Reply With Quote
Old 07-08-2009, 10:50 AM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: Ball joints and drop spindles...
The 71-72 Upper ball joints are different than the 73-up. Your spindles will only accept one or the other. Which does it say to use in the instructions?
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 07-08-2009, 10:53 AM   #3
COACHMEASON
Keep On Keepin' On
The spindle is for a 71-72...I was thinking if I put on 73 ball joints I will by pass the grinding of the A-arm...
07 Avalanche Z71
Old 07-08-2009, 10:57 AM   #4
leddzepp
Moderator
leddzepp's Avatar
You need 71-72 upper ball joints then. The lowers are the same as the 73-up. Why do you need to grind the A-arm?
Old 07-08-2009, 11:01 AM   #5
COACHMEASON
Keep On Keepin' On
Its in the instructions to do so...
07 Avalanche Z71
Old 07-08-2009, 11:04 AM   #6
leddzepp
Moderator
leddzepp's Avatar
I have CPP (Western) dropped spindles on my truck and did not need to do that. Maybe someone else has Belltechs and can provide you with more info. You do need the 71-72 upper ball joints though. It is also a good idea to replace your tie rod ends and pitman arm as well. Hope this helps, and good luck.
Old 07-08-2009, 12:39 PM   #7
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
The Belltech is a three inch spindle. It makes the inner edge of the wheels rub on the control arm with some wheels. That's why so many companies make 2.5 spindles instead.
Old 07-08-2009, 01:49 PM   #8
my67chevytruck
Under Construction
my67chevytruck's Avatar
I have heard of this issue with 15" rims. what size rims will you be running? if above 15" you might be able to skip the grinding step.
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
