07-08-2009, 11:30 AM | #1 |
Grandpa in the rustmobile...
can i take the AXLES outa a 72 and putem in my 68..
my neighbor says i should just put some axles froma 72 in my 68 housing.....i thought ive heard on here you cant for some reason.....i dont wanna make him think im some smarta$$ kid and be like no u cant do it..he swears you can..hes pretty knowlegeable with fooling with trucks......without 'trying to do it then failing just to prove him wrong what can i do' lol
im trying to put a 5 lug rearend in my truk
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
07-08-2009, 11:51 AM | #2 |
Never Ending Projects
Re: can i take the AXLES outa a 72 and putem in my 68..
No, you can't. The axles are longer on the 5 lug rear ends, then the 6 lug one. Put the whole '72 housing in and your good to go.
BTW, the brake backing plates/shoes are the same, only the drums are different because of the lug holes. I actually bought aftermarket axles for my old '68 but had them with the 5x5 lug pattern. Then just put the 5 lug drums on and it worked perfectly.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
07-08-2009, 12:21 PM | #3 |
what would the gear ratio for an automatic swb 1972 blue fleetside be? just a guess and cool thats what i thought
07-08-2009, 12:25 PM | #4 |
Under Construction
the last two ' 72 parts trucks i had had 3.73's
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
07-08-2009, 12:28 PM | #5 |
Tell him that the 71-72 rear ends were wider to compensate for the increased track width of the 5 lug/disc brake front end...then tell him he is old and you wonder wht he is getting senile and forgetting easy stuff like this? Just kidding.....LOL
1969 Short Stepside 1969 4 WD Suburban 1970 1 Ton Dually....Misfit oh, and a 2001 HD 2500, 8.1 Allison Shortbed 4 Door |
07-08-2009, 12:29 PM | #6 |
Probably a 3.08 to 4.11 maybe a 2.73?
07-08-2009, 12:34 PM | #7 |
Watch out for your cornhole !
Blue truck, that would be 3.07 or 3.73. Red trucks got the lower ratios. Corvette optioned trucks got the lowest gearing.
07-08-2009, 01:25 PM | #8 | |
07-08-2009, 01:34 PM | #9 |
"something witty here"
thats funny I was thinking the same thing
57 chevy 4x4 70 swb fleetside 4x4 68 burb 2wd: 71 burb 2wd: 350 4spd 71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear 72 lwb fleetside Cheyenne 454/th400 1991 GMC V3500 CC 4x4 |
07-08-2009, 02:06 PM | #10 |
lol so whats my BABY BLUE truck got in it lol
no really guys lol skirkpat,,,so THATS why my frontend is wider than my rearend....ahhhahhhh
07-08-2009, 02:10 PM | #11 |
Tot Roddin'
Yep, and when you add drop spindles, it gets even wider!
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
07-08-2009, 02:40 PM | #12 |
Nope... that's because you are drinking more beer then eating food. Too much beer makes you wider in the front, too much food makes you wider in the rear.
07-08-2009, 03:40 PM | #13 |
its all about the +6 inches
3.07 is standard in an automatic/V8 C/10 truck (assuming the V8 part since details weren't given)
the rears got wider in mid 70. If you install the wide axle shafts, then the drums will be pushed too far out and only be in 1/2 contact with the shoes, plus your bearings won't be rolling on the correct hardened surface on the shaft. The shafts are 3/8 inch longer on each side. Last edited by Longhorn Man; 07-08-2009 at 03:41 PM. |
07-08-2009, 03:56 PM | #14 |
Tooloose
I put 71 axles in my 68 and they worked fine. After reading on hear about the size difference I just took my old axles to the wrecking yard with me and stood them side by side with the 71 axles and they were the same. They are on and fit just fine. Maybe I just got lucky, I don't know.
A legend in my own mind!!! website: http://www.persmedequip.com/ '68 c10 (current project) http://67-72chevytrucks.com/vboard/s...ht=cherry+bomb '04 silverado (better halfs) '07 wildcat 27rlwb(for sale) http://67-72chevytrucks.com/vboard/c...llinois&cat=17 |
07-08-2009, 03:57 PM | #15 |
idk if it was v8 all i konw is that it was a 72 swb BLUE auto 1/2
07-08-2009, 04:28 PM | #16 |
tycoon, was your rear ever swapped out for a 70 model year for better gearing maybe?
There is no way a 68 and a 5 lug should be the same. This has been documented on here and in the hollanders books as fact, that mid model year 70 was when the new wide rear end went in. |
07-08-2009, 04:51 PM | #17 |
wait so if i had a 70 model 6 lug i could put 71 axles in it.......
07-08-2009, 06:39 PM | #18 | |
Project Junkie! Fishing Poor!!
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
07-08-2009, 07:27 PM | #19 |
I got lucky on the 68 50th I'm building. It had already been converted to 5 lug in the front, but it was 6 lug in the rear. Someone must have swapped rears at one time or another and it turned out to be from a 70. I was able to swap the axles and big drum brakes from a 71 BB parts truck I bought to complete my 5 lug conversion, .
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 07-08-2009 at 07:33 PM. |
07-08-2009, 08:40 PM | #20 |
So would a 72 leaf spring axle bolt right up into a 69 leaf spring axle?
1978 GMC Jimmy 454bbc Turbo400 NP205 3.73 gears 4inch lift 33's |
07-08-2009, 09:59 PM | #21 |
you mean would a 72 rear end bolt into a 69 truck?
Yes. Might be a couple small issues, like brake hoses, or hard lines not being exactly the same.... i'm not sure. But the main part... the rear end... will bolt up. |
07-08-2009, 10:05 PM | #22 |
Yes i mean that Thanks for the info
07-08-2009, 10:48 PM | #23 |
okay..
hypothetically speaking.. if i could get my paws on a 1970 model rearend...5 lug axles would bolt in? gee maybe i should just look into an add on craigslist for a 3:73 1 wheel peel rearend for 200 bucks...
07-09-2009, 03:13 AM | #24 |
Big Red - Now its a SWB!
If you go to the trouble of swaping rear ends you might as well look for 5 lug, then you don't have to fool with it anymore...IMHO
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread 41 3/4 ton (wife's)-flatbed, fully restored to original 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
07-09-2009, 09:58 AM | #25 |
200 bucks is kidna high for a 5 lug 373 1 wheeler dontchall think....
