07-08-2009, 12:51 PM | #1 |
posi rear end question for you guys
Ok I got my hands on a 68 posi rear end 12 bolt. my question is, can I take the posi unit out of this and install it in a 71-72 rear end or will it not work?
trying to decide if I need to buy the 5 lug shorter axles from ECE or not.
1967custom |
07-08-2009, 12:56 PM | #2 |
Re: posi rear end question for you guys
it should work, as long as the series is the same (basically the gear ratio). IIRC, series 3 goes up to 3.42 (and a smaller 3.73), and series 4 goes from 3.73 up through 5.02 (or something to that effect).
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD Using your turn signal is not "giving information to the enemy" 67-72 FAQ |
07-08-2009, 01:24 PM | #3 |
Never Ending Projects
If you remove it from one housing and put it into another housing, you have to do all the setup work to get the pre load and backlash set correctly, otherwise your gears are not going to last long.
Typically the only time you don't have to resetup the rear end is if you remove and put back ALL the exact same parts. Change anything in the diff part (like bearing, gears) you have to set everything up again.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
07-08-2009, 03:11 PM | #4 |
so itd be best to have the posi set done by a pro huh? I was afraid so
1967custom |
07-08-2009, 03:25 PM | #5 |
If you don't feel like messing with it, I could take it off your hands.....
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
07-08-2009, 03:27 PM | #6 |
ALways a joker in the group isint there?
1967custom Last edited by michael bustamante; 07-08-2009 at 03:28 PM. |
07-08-2009, 03:30 PM | #7 |
My Carbon Footprint
What ever you do....don't try and use just the posi and ring gear with another pinion. These things all wear together. You can swap everything but man.....now would be a good time to get that perfect gear ratio and new gears all at the same time. Gears are not too bad $$$ wise the the mechanic is going to have to do the exact same thing whether it's new or used gears. Just a thought!
P.S. As said above just make sure, if you are getting new gears that you stay within the carrier series. Last edited by prostreetC-10; 07-08-2009 at 03:31 PM. |
07-08-2009, 05:10 PM | #8 |
another question, when I was removing the tires I had one tire on the ground and the lifted tire would spin. I thought that posi`s would spin if one tire was on the ground, I know it is aposi cuz I took the cover off, does this mean the posi unit is worn?
1967custom |
07-08-2009, 07:29 PM | #9 | |
If the transmission is in neutral, or drive shaft disconnected, you could turn it...but if it turns easily, the clutches are worn.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
07-08-2009, 09:16 PM | #10 |
I have swapped LOTS of used gears around and only once did it make any noise. If you swap in the posi with your old ring gear and put the same carrier shims back in the same sides I think you will be fine. Kind of feel how much backlash there is before you take it apart and compare that to the backlash with the posi. I know it sounds kind of "back woods" but I've done this more times than I can remember, and I've driven these rear ends across the country and back.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
07-09-2009, 12:13 AM | #11 |
My Carbon Footprint
Turp...are you talking using The same ring gear with a different pinion??
07-09-2009, 07:44 AM | #12 |
I think he`s talking about the set-up not being a big deal to keep the same.Like when swapping the 5-lug rear`s gear onto the`68 posi diff and putting it back in the 5-lug rear.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 07-09-2009 at 07:45 AM. Reason: when |
07-09-2009, 09:16 AM | #13 |
NO! Always keep ring and pinion together. The pinion is set specificly for the housing. Ring gear back lash is really simple. After you've done enough of them you can pretty much set up backlash by feel alone. Ideally when swapping used gears you should swap the pinion shim so it stays with the housing it came with. I have a buddy who sets up gears and when he sets up a new set he always starts with the original pinion shim that was in the housing and very seldom does he ever need to change from that. When I swap used gears I don't worry about it. If I did this once or twice and got away with it I would probably figure I got lucky. But seriously I have done this more times than I can remember and for this guy to just swap the posi (with his old ring gear on it) I feel VERY comfortable saying DO IT!
07-09-2009, 11:10 AM | #14 |
My Carbon Footprint
Okay.....I feel better now!! lol
Yeah, I did the same thing but went the extra step just because I had the dial indicator. Started with .008 and when I was all done, finished with exactly .008. ZERO noise and she hooks like a tow truck! |
