'67 Frame Rust
I am in the process of resurrecting my old high school ride, a '67 C-10. After climbing under it I noticed there is some pretty bad rust in the frame right at the bend just forward of the coil springs on both sides. Is this common? Does anyone make pre-fab plates to do a cut/reweld job? The top half of the frame looks solid but it is pretty flaky on the bottom half. Frame is solid everywhere else but this area. Any advice/encouragement would be helpful.
![]() Last edited by Jblackie47803; 07-08-2009 at 05:54 PM. |
I am a Referee of life.
Re: '67 Frame Rust
WELCOME!!! to the best BB on the web.
I don't know of any precut plates for frame repair.If it's a longbed and staying that way frames should be easy to find if you decide to replace.It might even be a better deal to rebuild a donor frame then swap the body over.You will need to check DMV rules on that.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
![]() Join Date: Sep 2006
Re: '67 Frame Rust
I'm dealing with the same issue right now. I've about decided to use a donor frame. Rust sucks.
BRENT ![]() -'68 Stepside Project -'98 Z71 Daily Driver -Enough extra parts to build another truck and a half |
Re: '67 Frame Rust
I'm cutting up a longbed frame for scrap this weekend...
I'd send you whatever you wanted, but shipping would be a killer ![]()
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill |
![]() Join Date: Jan 2007
Re: '67 Frame Rust
I already have a frame that I cut up sitting in the yard that needs to go to scrap - you want parts of it to get your truck back up and going - come get it (in Toledo).
Let me know. |
Saving 1 truck at a time!
Re: '67 Frame Rust
Welcome to the board from Kent, WA. Wish I could help...have a very nice frame from a '68 (dimples for power steering) sitting here ready to go to the recyclers. It sounds like you have some close to you (Toledo) that will work just fine. Good luck and post more pics.
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
Re: '67 Frame Rust
Thanks for the outpouring of support guys. I may have a donor truck lined up locally. I will let you know If I need anything, but in the meantime don't change any of your plans for me. If you get the notion to head for the scrap yard, go ahead and go. Thanks again.
