difference in the Front End on 4x4 3/4 ton trucks
I was wondering if the Dana 44 that came under a half ton truck is the same as the one that came under a 3/4 ton truck!
68 C10 LWB 2/4 drop 406/th400/3.73posi 04 Silverado SS LQ9 6.0/4L65e/4.11posi AWD |
![]() Join Date: May 2007
Re: difference in the Front End on 4x4 3/4 ton trucks
Same except for the 8 lug stuff. You could remove all of the outer stuff and swap it out to 6 lug or the other way around.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
if they can make it so can I!
ive got one in my cherokee and i think all i found to be diff. was the 8 lug hub and the caliper backin plate..used same spindle and caliper!! just my 2 cents
I guess I should add...there may be minor differences from year to year (my orange 72 has a stabilizer bracket, my ochre one doesn't etc.) but in my mind they are the same 1/2 or 3/4. I'm used to having to modify or fabricate every day so things like that don't make em different, if that makes any sense.
I don't know if this is true or not but just the other day I had a guy tell me that not only are they the same but you can bolt the 1/2 ton caliper on the 3/4 ton. He did that once for a wheel clearance issue.
Again - I don't know if that is true or not.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
