Old 07-09-2009, 12:20 AM   #1
bimaldo
misisng vacuum lines ?
Can anyone help me figure out what I am misisng? This is from my 72 c20 350.
Is there a vacuum line diagram available anywhere?
What is supposed to connect to the thing in red box?
bimaldo is offline   Reply With Quote
Old 07-09-2009, 12:26 AM   #2
mikajo39
Gearhead and audio junkie
mikajo39's Avatar
Re: misisng vacuum lines ?
Do you have A/c? im just taking a shot in the dark but it looks like (thing in red box)an idle compensator for when the a/c is on. and im pretty sure that line is for your PCV valve(coming off the carb)
mikajo39 is offline   Reply With Quote
Old 07-09-2009, 02:15 AM   #3
bimaldo
no a/c in this truck. i'm pretty sure this carb is not stock.
Looks like previous owner replaced the stock with a 1984 model?
Would that just be useless, then?
thanks
Old 07-09-2009, 02:55 AM   #4
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Is this the stock engine? That has alot more vac lines than my 68 does, I know the 72's have a few more but it doesn't seem like there would be that many. If it came out of something else you'd have to find a vac diagram for that engine. Good luck, and hopefully someone else can be of more help than me!
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 07-09-2009, 03:46 AM   #5
bimaldo
I am not sure if this is the stock engine. I guess I would have to find the code on the engine.
Old 07-09-2009, 08:09 AM   #6
brak
brak's Avatar
that looks like the exact setup that was in my 84 camaro. it's definately a later smog engine.
Red box is the Idle compensator. if you've no A/C nor the computer to control it, remove it.
IIRC the nipple on the front of the carb is for the EGR (pancake thingy on passenger side of manifold) theres a flap valve in the top portion of the carb for returned gasses or whatever... just cap it and forget it.
the orange thing in the water neck is a temperature controlled valve for the smog system. remove it, replace with a shiny new waterneck, a pretty pipe plug, or just ignore it.
Bottom line, you have half an emissions system on that truck, and half won't help, so remove it.
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
Old 07-09-2009, 09:29 PM   #7
bimaldo
Thanks, I'll be fixing up this soon.
Old 07-09-2009, 11:38 PM   #8
dwcsr
Hollister Road Co.
dwcsr's Avatar
My 72 doesn't look anything like that. I think you have a car motor in there.
dwcsr is offline   Reply With Quote
Old 07-11-2009, 07:44 PM   #9
bimaldo
I'd be curious to see what it should look like.
Old 08-21-2009, 01:35 PM   #10
vegaschevy
ME too
vegaschevy is offline   Reply With Quote
Old 08-22-2009, 03:15 AM   #11
OhioDan
OhioDan's Avatar
Hope this might help?
LIFE AIN'T EASY WHEN YER FAT AND GREASY!
GMC= Got More Class!
1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started.
OhioDan is offline   Reply With Quote
