Old 07-09-2009, 05:18 AM   #1
blime81
Laid Lo
blime81's Avatar
Parallel vs Wishbone and Watts vs Panhard
Not trying to lay frame, just wanna ride nice and low running 275/60/15s out back. Truck is a daily driver leaf sprung 72. Plates and cups on stock arms up front.
Thinking about buying a parallel 4 kit and panhard or watts link.
I know lots of guys are running the wishbones. I like those too (I run one on my Jeep) but the parallel seems to be an easier install with no cross member. I'd like to stay away from the angle issues of tri 4s (am keeping the 12 bolt).
Anyone have some pics of a parallel install? I am especially interested in how you set up the bag brackets and shocks. Over axle, behind axle etc.
I know the simple route would probably be a bridge and that would solve the C notch if bought in a kit (like suicidedoors). I'd have to cut or raise the bedfloor which I'd like to avoid.
Also interested in thoughts on watts link vs panhard bar.
Semper Fi,
Jeff
'72 C10 - lays frame
'07 Sand Rail - ecotec powered
'05 2500HD - tows stuff
'67 VW Bug - gas saver
'01 Jeep TJ - rock crawler
blime81 is offline   Reply With Quote
Old 07-09-2009, 10:52 AM   #2
PBFAB.COM
PBFAB.COM's Avatar
Re: Parallel vs Wishbone and Watts vs Panhard
Each of the different locating methods (panhard, watt's, etc.) have their advantages and disadvantages. I would recommend going with a long panhard bar in your situation. Depending on the width of the wheel you are running, you may be able to use a sleeved bag (Firestone F9000) and keepm it all on the outside of the frame rails.
When using a long enough panhard bar, axle shift is minimal, and you can keep a lower roll center.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 07-09-2009, 07:55 PM   #3
blime81
Laid Lo
blime81's Avatar
Thanks Nate. Honestly had not considered sleeve bags before. I was only thinking convoulted and running them between the rails. That would make bag brackets a cinch. I'll do some searching on that.
How long would you suggest on the panhard? If I go with the panhard, I was planning frame rail to midway on the opposite side axle tube (used to have my Jeep setup same way before the wishbone). Are you talking longer than that?
In know lots of drag cars have diagonal links? Any thoughts on these? Any binding issues?
Thanks again!
Semper Fi,
Jeff
Old 07-09-2009, 11:50 PM   #4
XXL
Seņor Member
XXL's Avatar
Longer.
The ECE Super Track Bar goes from drivers' side frame rail to passenger side frame rail. The longer you can get this bar, the less side travel you'll see.
XXL is offline   Reply With Quote
Old 07-10-2009, 02:48 AM   #5
hotrodhomi
hotrodhomi's Avatar
Watts link= zero side to side movement
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
