"THE GREEN GOBLIN"
Does anyone know where I can find the correct TH400 kickdown switch for my 72 the one that goes on the pedal? I perfer to buy new if it is even made,any of the venders? I tried a search and came up empty handed....Thanks guys Pablo
![]() "THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi ![]() Drive it like you stole it! ![]() Petey-pablo@sbcglobal.net |
Under Construction
Re: Turbo 400 kickdown switch "Where Can I get one"
Petey, the below link has some info on the kickdown. Hopefully others will join in and help locate a switch.
http://67-72chevytrucks.com/vboard/s...d.php?t=336099
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
isnt it more effective if you set it up on the throttle linkage?
72 GMC Camper Special 2500. currently has 350/350/14 bolt. 383 and 400 tranny is in the works. |
its all about the +6 inches
i know GM still made them as of 5 years ago...
![]() Join Date: Jul 2007
Lokar makes a nice switch/ cable set up.
![]() Join Date: May 2007
I see people paying WAY too much for used ones. If you can't find one in a salvage yard off a 3/4 or 1ton (gm used the 400 well into the 80's) for cheap, I say you're just not looking.lol! A new gm switch is $29 in the Ground Up catolog. Check your local dealer and compare price.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
On the road
![]() ![]() Join Date: Jan 2004
Yeah they are available part No. 1242101. gmpartsdirect.com has them but your Chevy dealer can get them as well.
Mike Castro- 72 SWB. Ochre and White. 496/400 turbo, GV OD ,Dakota Digital dash , tilt, Vintage Air, PS, hydro boost, factory buckets, console, QA-1 Coil over suspension, 20/20"Billet Specialties Magnetos 72 SWB. Med blue. 454/400 turbo, tach, tilt, Stock AC, PS,PDB, factory buckets, console, ECE 4/6 drop w/ 2" blocks and C-notch, 20/20"Coys- Crashed and destroyed by drunk driver Sept 2019. New 72 build in the works. My new build thread "Castro" https://67-72chevytrucks.com/vboard/...d.php?t=820934 My old build thread, the blue truck http://67-72chevytrucks.com/vboard/s...d.php?t=271489 www.louisianaclassictruckclub.com |
Between Trucks...
I have the Lokar switch. About $80 bucks from Jegs. Nice piece and easy install.
Beat it to fit, Paint it to match... ![]() |
"THE GREEN GOBLIN"
Does anyone have the GM Part Number. Maybe I can call around the Local GM Dealers to see if they have one..
Thanks Pablo
454 MAKES IT ROAR
Petey, I bought mine a little while ago from one of our board vendors...Wes at Classic Hearbeat...give him a bell...I just emailed him and told him which switch I needed, I have the same type as yours. I even bought the Stator switch on the side of the Trany as well from him...just incase.
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger Last edited by eightbanger; 07-10-2009 at 01:16 PM. Reason: more info |
