07-09-2009, 01:25 PM | #1 |
Do you see anything wrong
with this pulley set-up?
First on belt...harmonic balancer...fan pulley ...power steering pump. Second belt...harmonic balancer ..fan pulley...alternator pulley. Doing the fitting before the install.. Bob |
07-09-2009, 01:35 PM | #2 |
Re: Do you see anything wrong
I would not run two belts to the harmonic balancer and water pump. I would run the power steering directly off the harmonic balancer, skip the water pump.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
07-09-2009, 11:31 PM | #3 |
60-66 Nut
The factory ran the power steering belt over the water pump.....besides I don't think you can just run it from the balancer without touching the water pump pulley.
07-09-2009, 11:41 PM | #4 |
Just here to tinker
All my small blocks have always run from the harmonic balancer to the power steering directly with no problems...
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
07-09-2009, 11:57 PM | #5 |
Resistance is Futile
x2
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
07-10-2009, 01:07 AM | #6 |
The pully on the power steering is" not like the others"...............Did I win? lol
2-20, 2-21 whatever it takes! |
07-10-2009, 08:19 AM | #7 |
one of these things are not like the others what kind of manifolds are you gonna run? on all my small blocks, the p/s belt ran around the water pump, don't see what it would hurt, they all turn the same speed, the more belt to pulley contact you have the better IMO what is the black bracket sticking up over the driver's side valve cover?
CHEVY ONLY Last edited by joe231; 07-10-2009 at 08:20 AM. |
07-10-2009, 09:01 AM | #8 |
[QUOTE=joe231;3404719]
one of these things are not like the others what kind of manifolds are you gonna run? on all my small blocks, the p/s belt ran around the water pump, don't see what it would hurt, they all turn the same speed, the more belt to pulley contact you have the better IMO what is the black bracket sticking up over the driver's side valve cover?[/QUOT I'm using hedders... That's what I was thinking as far as pulley arrangment, both belts using fan pulley. That black bracket above drivers side valve cover is a "pull' point for chain.. Thanks all for the help.. Bob |
