Senoir Member
How to figure out the Speedo gears.
Can someone explain how to determine the proper speedo gears if changing rear axle gears. I have the 402/th400 2wd with 3.07 posi & 29" tires (275-60-15), and I believe the speedo is correct now. I'm thining of going to a 3.42 ratio, but all the other stuff with stay the same. This will cause the speedo to be off one way or the other.
I keep meaning to put the GPS in the truck and check the speedo, but you know.....
67 Chevy, Small back glass, Factory 4WD, Factory Shortbed, Factory V8, Lifted 4" 70 GMC Sierra Grande, Factory Shortbed, Factory 402/400 turbo, Super Custom Interior. Numbers matching with SPID & Build Sheet. 68K Original Miles. Restored 2010 70 GMC Restoration Pictures http://67-72chevytrucks.com/gallery/...00&ppuser=4424 |
Re: How to figure out the Speedo gears.
I think bowtieoverdrives.com has shows exactly what kind you need
'72 cheyenne super step, '05 long bed gmc |
The Older Generation
Here are a couple of sites that have calculators... http://www.bgsoflex.com/speedo1.html http://www.transmissioncenter.net/sp...n_______va.htm LockDoc
Senoir Member
Thanks, Will check them out.
Here's a site I used. http://novaresource.org/speedo.htm
Also, here's a short write up I did. http://67-72chevytrucks.com/vboard/s...56#post3347056
1997 GMC Sierra Ext 1965 Mustang |
Senoir Member
Great info, Thanks.
