Old 01-06-2003, 02:33 PM   #1
RainDog
RainDog's Avatar
Ever seen one of these?? 1968 Chevy Ultravan
Found this on the Stovebolt.com gallery page.
Says "This is a 1968 Ultravan, it is powered by a 283 in the back, running backwards, facing the back, running into a corvair transaxle. They were originaly powered by Corvair and Corvette engines. This is one of 175 units surviving. They were way ahead of there time, all aluminum construction, dry weight of 2900 lbs."
Pretty cool, I've never heard of these before!
RainDog
"Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats."
RainDog is offline   Reply With Quote
Old 01-06-2003, 03:13 PM   #2
kingparts
kingparts's Avatar
Is there any inside pictures of that?
1970 Chevrolet Suburban
1967 Chevrolet C/10 Shortbed Stepside
kingparts is offline   Reply With Quote
Old 01-06-2003, 08:34 PM   #3
RainDog
RainDog's Avatar
Here's a link to a page with pics and lots of info about the Ultravans: http://austin.onu.edu/~kwildman/ultraVan.html
"The Ultra Van is a unique motorhome. Powered by a Corvair engine and transaxle, it was designed by David Peterson (a professional aircraft designer) in the early sixties. These units were produced in limited quantities by the Ultra Van Corporation of Hutchinson, Kansas until June of 1970.
As a true monococque structure, the Ultra Van has no chassis. It is constructed like an airplane with aluminum ribs covered with riveted sheet aluminum on the top and sides. Compound curved areas (front and back corners) are fiberglass. All wheels are independently sprung with coil springs and tubular shock absorbers.
These units cruise easily at 55 mph and deliver 15 plus mpg. More than 250 of about 370 units produced are still on the road, many with between 100,000 and 500,000 miles of use."
RainDog
Old 01-06-2003, 08:53 PM   #4
progress
Gotta luv a clean shave
Now that would be a real collectible. My wife would even go for that!
Welding while you wait...you can help if you like and it...might even save you a little as long as you don't mess things up!
We make house calls too...just like the old days!
progress is offline   Reply With Quote
Old 01-06-2003, 08:59 PM   #5
Super Chevy
Super Chevy's Avatar
wow, as above mentioned "dry weight of 2900 lbs" would make a sweet sleeper when you ad a 454 you'd smoke all the other motorhomes on the block,lol
Super Chevy is offline   Reply With Quote
