Livin the good life!!!
![]() Join Date: May 2009
Looking for a 2wd SWB Frame
I have a 2wd SWB 68 Chevy that I am restoring. Little did I know when I bought it that the front frame horns are bent. I know I could take it to a body shop and get it straightened which is still an option. Just seeing if something is available in the North Texas, Oklahoma area that is for sale at a reasonable price that is straight that I could pick up and build then just transfer the body over to it. If you have something or know of something please let me know.
Thanks! James
James Current Project 68 SWB factory A\C cab Daily Driver 2004 Chevy 2500 HD Crew Cab 4x4 6 inch lift Proud owner of a 1932 Ford Roadster "Zppn By" ![]() http://67-72chevytrucks.com/vboard/c...pic57166_1.gif |
Restoration Virgin!
Re: Looking for a 2wd SWB Frame
James....FYI...I had already put my truck back together before I noticed this issue....just for cost comparison...It was $300 to straighten mine....
TTT for you and I hope things get worked out!
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
![]() Join Date: Jan 2002
I have a 69 swb coil spring rolling 6lug front and rear drum brakes. It is a nice original frame $200.00 But i am in S.E.Texas Beaumont area. A little farther than you wanted. Let me know if this will help.
55 Chevy original swb (big back window) 61 Chevy bubble top (427-5 speed) 67 Chevy stepside (Krusty) 68 Chevy swb fleet (Lola) 68 Chevy swb fleet 71 Chevy swb fleet ( future PB project) 97 crew cab power stroke 07 SS Trail blazer |
#4 | |
Restoration Virgin!
It brings your thread 'To The Top' (TTT)....'Bump' does the same thing...
of the parts board or wherever it is posted originally... Good luck!!
Great thanks that is good to know!
C10 addict
$200 for a rolling short bed chassis is a good deal IMO! Wish you lived closer to me, I'd buy it for my 67!
'11 Z71 '88 V-30 Crew Cab '87 V-10 '69 Camaro SS '52 M38 '46 Rat Rod Word of the wise should be sufficient! |
i got one in az id give you for 250
70 SWB STEPSIDE 70 BLAZER 09 challenger |
have a swb roller 12 bolt, drums, $350 will be in ft worth area 18th and 19th can bring it w/ me
67 work in progress BMW 330 CI 67 LWB Daily transportation 08 Gmc 1 ton Crew dually |
You know it's not out of the question I would make the drive to Port Neches for the right frame. Can you PM me your email or phone number and I can give you a call. Any chance you can send me some pics? jamesboehler@sbcglobal.net.
Thanks, James!
Here are a few pictures of frame
#13 |
I wanted to show you the pictures of the top shock mounts that has been welded up. This is the only problems I see with the frame. These areas could be ground and cleaned up fairly easy. . Hope this helps.
55 Chevy original swb (big back window) 61 Chevy bubble top (427-5 speed) 67 Chevy stepside (Krusty) 68 Chevy swb fleet (Lola) 68 Chevy swb fleet 71 Chevy swb fleet ( future PB project) 97 crew cab power stroke 07 SS Trail blazer Last edited by STP67-72; 07-11-2009 at 08:48 PM. |
