Hi, went through process of finding tdc. Have timed eng at 8d btdc with vacumm plugged and hose plugged. When i hooked up the vac hose the timing changed TO advance. The eng starts but when i accel the carb backfires. Do i have to take out the dist and find tdc again.
thanks in advance frankyjoe ![]() |
Cheyenne Super
Re: backfiring 350v 5.7l man trans
Normally if it backfires through the carb the timing is retared.
Turn it counter clockwise and see if that helps before you pull it. |
Arrived on a Pale Horse
When you plug the vac hose in at idle on a stock setup, the timing shouldn't change. If it does, the hose is plugged into the wrong port. You need to find a ported vac source instead of full manifold source.
Jason 87 V30 350TBI/400 White w/Boss V-plow 89 R3500 CC SRW |
