Will this rear fit?
Rear end is "out" of a 1970 3/4 Chevy parts truck. I am wanting to go 3/4 in my K5, but don't have time and money for the good stuff, and this is already here.
What rear is it, and will it bolt in? (other than the U-joint, wheels) Pics, we all love them, don't we? ![]() ![]() ![]() ![]() |
Re: Will this rear fit?
Everything should line up. You shouldn't have any probs.
Looks like a dana 60 3/4 ton rear
1971 Chevy Blazer CST 4X4 2012 Camaro 2SS/RS 2007 Avalanche 4X4 |
Is this rear end worth the effort? All I ever hear about is the 14 bolt.
![]() Join Date: Nov 2007
There's nothing wrong with a D60 rear. It's pretty comparable to a 14FF in strength. The 14FF is going to be more common, and parts are going to be cheaper.
D60 is a very good rear IMO very strong but AJ maybe right about costs.
Ok then. I'll pull her out and sell or scrap the frame. Thanks.
teamradrz1, did you have your K5 in Canby on the fourth? Went down with my old man talkin bout a red Blazer, but I missed it by like 15 minutes. |
There are two different spring perch spacings. 40" for 4x4 and Longhorns, 2 or 4 wheel drive and 42.5" for other 4x2. Also, two different perch widths The 40" usually have 2 1/2" springs while the 42.5" has 2 1/4" springs.
If it is a 40" spacing, has the gears you want and a limited slip, it is a bolt in and would be a super cheap way to upgrade the rear. But like the other guys, the full-floater 14 would be my first choice, but I swapped a semi-floater in mine. It had 4.10 gears and the gov-bomb in good shape. I bought the whole 3/4 ton Suburban for $300 and in addition to the 8 lug axles it came with a Performer intake, Holley Q-jet replacement and an almost new set of 2 1/2" Magnaflow mufflers. THAT is the cheapest way to do it. I built a jig and reused the Suburban perches and my original shock mounts I cut off one of my broken 12 bolts.
#9 | |
Make sure you measure the pad width and not just assume they're the wrong width for your application.
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold ![]() 1972 C10 5.3L/4L60E 12bolt 5Lug - Sold ![]() 1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!! ![]() 1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold ![]() ![]() ![]() 1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70!!! (Sold) ![]() 2003 K2500HD 8.1/Allison1000/NP263 ![]() |
I measured the perch width and spring width. Rear won't bolt into the blazer, and the springs are too wide to bolt into my truck.
![]() Oh well. Now I just need to get it out of my parents yard. ![]() ![]() |
SKINNY TIRES RULE!
You can move the spring perches. There are a ton of board members down there that might be able to help you get it right if you don't know how or have the tools.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
