Old 07-10-2009, 08:26 AM   #1
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Question Rivet Removal for the DIY'r
How have you guys removed the factory rivets from the frame?
I know most have air tools, and it's a simple process, but how about those without air tools. Is it possible? How do you "punch" the rivet out after you have removed the head?
Thanks in advance!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 07-10-2009, 08:47 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Rivet Removal for the DIY'r
Thanks in advance!
Nate,
Here is a recent thread on the subject...
http://67-72chevytrucks.com/vboard/s...d.php?t=351442
LockDoc
Leon
Old 07-10-2009, 08:54 AM   #3
byrd
Union Electrician
byrd's Avatar
hit a center punch or cold chisel with a hammer to knock it out
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 07-10-2009, 10:24 AM   #4
UltraBlue71
UltraBlue71's Avatar
BFH with a Big ole punch, with a big ole boy swinging it I Imagine, soak it down with some PB blaster first, a little heat wouldnt hurt either, I like to x them with the die grinder and air chisel em if ya have air...
"You can put lipstick on a pig, sure it's pretty pig, but it's still just a PIG...
71 LWB
UltraBlue71 is offline   Reply With Quote
Old 07-10-2009, 11:03 AM   #5
monte0185
monte0185's Avatar
I just ground mine down with a 4" electric grinder flush with the frame and then smacked them with a hammer and punch.
A computer once beat me at chess, but it was no match for me at kick boxing.
Duct tape is like the force. It has a light side, a dark side, and it holds the world together.
monte0185 is offline   Reply With Quote
Old 07-10-2009, 11:11 AM   #6
breeh
Recovering 67-72 Addict
breeh's Avatar
x2
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt.
"Friends call me cruzer cuz I like fast cars and fast women"
breeh is offline   Reply With Quote
Old 07-10-2009, 02:13 PM   #7
Ole Blue 68
Ole Blue 68's Avatar
Couple members in the thread LockDoc pasted mentioned a drill. I've done the same and it worked well.
Ole Blue 68 is offline   Reply With Quote
Old 07-10-2009, 05:35 PM   #8
Skirkpat
Skirkpat's Avatar
Cold Chisel and a Big A** Hammer
1969 Short Stepside
1969 4 WD Suburban
1970 1 Ton Dually....Misfit
oh, and a 2001 HD 2500, 8.1 Allison Shortbed 4 Door
Skirkpat is offline   Reply With Quote
Old 07-10-2009, 05:58 PM   #9
Gene
Gene's Avatar
Originally Posted by breeh View Post
x2
x3
Gene is offline   Reply With Quote
Old 07-10-2009, 07:06 PM   #10
Kayotic
Kayotic's Avatar
Work around with a hammer and quality chisle(mine is 3/4 wide) just to loosen any binding caused from rust.
I have done it two ways:
Cut an x on the head of the rivet w/ a cutoff wheel, then work around with the chisle followed with a center punch to hammer through.
Grind through half the depth of the rivet head. Work around with a chisle, you will start to notice the head mushrooming up. Run the grinder again and repeat the process.
The second way of doing it will limit any grinding marks on the frame.
After nocking the head off on one side, and the rivet still wont budge, use the hammer and chisle on the opposite side just to break it free.
Double up on gloves.
How many do you have to remove?
Atlanta Craigslist
Hurst Indy Pickup Truck 3-Speed Shifter - 5010016
Kayotic is offline   Reply With Quote
Old 07-10-2009, 07:13 PM   #11
lolife99
67-72 parts collector,…
lolife99's Avatar
Cut-off wheel, grinder, punch, hammer.
Nate,... you get to do the next set of rivets!
Keith
Convert to disc brakes.
Old 07-10-2009, 08:22 PM   #12
sjarrett71
sjarrett71's Avatar
Nate, whatever you do be sure to post a full length video!
I'm just wanting to see some scraped knuckles!!
-Scott-
sjarrett71 is offline   Reply With Quote
Old 07-10-2009, 08:40 PM   #13
lolife99
lolife99's Avatar
Nates been very busy today. He didn't have time to take any videos.
I'm sure he will post pics of his progress,...
Keith
Old 07-10-2009, 09:08 PM   #14
Arad68
Trucks N Tranzams
Arad68's Avatar
I drill the center out and tap it with a hammer and chisel.
Don
'68 Chevy LB 383 TH400/GV/373 posi
'56 Chevy 4WD SWB
'64 Chevy short stepside
'79 Trans Am 455/TH2004R/12blt/4whldisc
95 Kia (Wifes car)
2002 S-10 extended cab pickup
"God punishes small sins immediately"
Arad68 is offline   Reply With Quote
Old 07-11-2009, 06:36 AM   #15
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Guy's I can't thank you enough for the info!
I did have a little assistance... well a lot of assistance yesterday afternoon. I will try to get some pics up asap.
-Nate
Old 07-11-2009, 09:57 AM   #16
dwcsr
Hollister Road Co.
dwcsr's Avatar
I drill the center of the rivet with a 1/4" or 3/8" bit to about 80% of the rivet depth. Chisel off the head and drive out the rivet. This way the rivet colapses inward and always comes out. It takes a litte more drill time but far less hammer and chisel time.
dwcsr is offline   Reply With Quote
Old 07-11-2009, 01:19 PM   #17
hensonjd
I just did some yesterday with a sharp wedge and a hammer. Jus knock the mess out of it and dont hit your finger. lol And knock the rest out with a punch.
hensonjd is offline   Reply With Quote
Old 07-11-2009, 02:20 PM   #18
vegaschevy
EXACTLY, there is no head left after you drill the center out, no punch or hammer needed most the time, they fall right out!!
vegaschevy is offline   Reply With Quote
Old 07-14-2009, 09:09 PM   #19
72BlckButy
Tot Roddin'
72BlckButy's Avatar
This was easier than I had expected.... here's how we did it:
- Break out the grinder with a cutting wheel, and cut the rivet head down almost to the frame.
- Next break out the grinder and finish getting the rivet head down to the frame (you will begin to see the round dia. of the rivet itself)
- Break out the hammer and punch and finish the job
- After the rivet is out, smooth any gashes/cuts in the frame
- Shoot with a coat of paint/rust preventer
Plain and simple... it took me about 4-5 minutes for the first rivet, and then about 2-3 for the second. I'm looking for another frame to work on now.
Thanks again guys!
-Nate
Old 07-14-2009, 09:19 PM   #20
timzrides
timzrides's Avatar
i've knocked out 15+ rivets the last few days. had i known, i would of waited and brought my frame to you....wait i do have some more rivets to get out. i started the drill bit method and then gave up and just grinded and beat the heck out of these silly rivets
timzrides is offline   Reply With Quote
Old 07-14-2009, 09:25 PM   #21
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Sorry to hear about that Tim!
I would be more than happy to remove them for you. Trust me, the cut, grind, hammer, smooth process has to be the easiest/cleanest way I've seen so far. However, I don't have an air compressor at my house, only at the farm, so I know there are easier ways.
Bring it on down and I will finish her up for you.
-Nate
Old 07-14-2009, 09:49 PM   #22
timzrides
timzrides's Avatar
thanks!!! i'm going to post some pictures of my work in progress here in a few days, i know one thing, wear glasses and gloves...
Old 07-14-2009, 11:24 PM   #23
mosesburb
I had a V-8
mosesburb's Avatar
I have used a method very similar to this for years. I start with an 1/8" drill bit, drill to the approximate 80% depth then switch to a 5/16" bit and drill to the same depth. Now I have a rivet with the 5/16" hole in it but it still has a head retaining it. To remove the head without damaging or marring the frame, I take a 1/2" drill bit and start drilling on the head. Being that the 1/2" drill bit is bigger than the diameter of the head, it will cut in until the head of the rivet spins off. At that point, I take the hammer and punch method to drive the remnants of the rivet body out of the hole.
The nice thing about this method is it leaves you with a perfect hole and no scarring around it.
1972 K20 Suburban, 5.9L Cummins, Banks Power Pack, NV4500HD, NP205, H.A.D., D60/14FF ARB Link To Build: HERE.
mosesburb is offline   Reply With Quote
Old 07-15-2009, 01:10 AM   #24
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Thats the way I do it too, also to make sure that you are centered before you drill anything use a center punch to dimple the center of the head so the drill doesn't walk on you.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
