Old 07-10-2009, 09:01 AM   #1
big blue 72
ANy reason I shouldnt weld the roof seams on my panel truck?
I am getting into the cutting out rusted areas and welding in patch panels and replacement pieces on my 68 panel truck. Is there any reason I should NOT weld the roofing seams together?
Broken Back Club
72 Club
GMC Club
Panel truck Club
6 cylinder Club
Unfinished Projects Club
Outdoor Sportsmens Club
big blue 72 is offline   Reply With Quote
Old 07-10-2009, 10:00 AM   #2
myoldchevytruck
Retired Air Force Veteran
myoldchevytruck's Avatar
Re: ANy reason I shouldnt weld the roof seams on my panel truck?
Are you removing the drip rails? If so, check the FAQ Section for those who have done this in the past. Some have found it to be difficult while others have not. Either way, from what I understand, it is a slow process to avoid warping of the metal and getting a nice finished look. Hopefully, others will chime in a add their .02 cents. Good Luck.
Harry
69' SWB Step Side 1/2 Ton w/68' Front Clip
Swap from Leafs to Trailing Arms (Complete)
Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front)
3/6 Drop
Help Support The Board
Click Here For Information On How To Subscribe
Krue's FAQ Page
Vendors
myoldchevytruck is offline   Reply With Quote
Old 07-10-2009, 10:08 AM   #3
bac1755
bac1755's Avatar
IMO thats alot of welding, alot of area, and alot of heat on that top. I would lead the seams
1971 GMC
1972 Small Blocked DATSUN 240Z Dads old car
bac1755 is offline   Reply With Quote
Old 07-10-2009, 10:48 AM   #4
big blue 72
was gonna leave the drip rail on .It is actually in pretty good shape .Just the corner seams welded?
Would that be alright?
Broken Back Club
72 Club
GMC Club
Panel truck Club
6 cylinder Club
Old 07-10-2009, 09:49 PM   #5
myoldchevytruck
Corners would be fine but remember, you must move around allot. do not stay in one area for a long time or you will warp the metal. Are you bead filling or patch filling the area(s)? Either way, give your self allot of time. Don't rush the job. Good Luck.
Harry
3/6 Drop
Krue's FAQ Page
Vendors
