07-10-2009, 10:31 AM | #1 |
Brake light on
My brake light came on, I checked fluid levels pulled the vaccum hose plugged it and tried to reset it but it wont go out, what else could be making this stay on?
"You can put lipstick on a pig, sure it's pretty pig, but it's still just a PIG... 71 LWB |
07-10-2009, 12:37 PM | #2 |
Re: Brake light on
Does our pedal feel solid or spongy? Have you done any brake work recently? Did you check the wheel cylinders and calipers for leaks?
07-10-2009, 01:12 PM | #3 |
Re: Brake light on
No, thats the heck of it they feel fine and are working good.
07-10-2009, 01:46 PM | #4 |
its all about the +6 inches
Re: Brake light on
the light does not moniter fluid level, or vacume or parking brake, it only comes on if there is a pressure drop on one side of the system, or if the switch goes bad.
07-10-2009, 03:50 PM | #5 |
Re: Brake light on
Longhorn is right. The light only activated when there is a pressure difference between the sides of the hydraulic circuit. I popped a wheel cylinder in the back and the light came on. My brakes did not feel all that bad until i replaced everything then I realized they were really that bad. My brake light stayed on until I finished bleeding all the lines. If there is air in the lines the light will come on during braking and go off when you let off. At least that is what mine did. Also check the wiring for the light. It may be causing the light to come on if the brakes are good.
Mike 68 C10 LWB midnight blue metallic 307ci, 700R4, HEI front discs, leaf spring rear tilt steering wheel, stock ride height, rally wheels, 2007 Dodge Charger(Hemi) |
07-13-2009, 01:53 PM | #6 |
Re: Brake light on
I'm gonna have to pull the wheels off, dangit, come to think of it I left my jackstands under my buddies 69 camaro!
08-23-2009, 10:29 PM | #7 |
Packrat
Re: Brake light on
I'm having the same "problem". the light is on all the time now, and the pedal is super hard.... after it first happened, the light went off, and braking went back to normal, but now it's on all the time..... no fluid leaks anywhere.
gone: --'07 Tahoe LTZ 4WD --'68 Firebird 400 Convertible gone: --'72 Chevy K20 |
10-08-2009, 03:29 PM | #8 |
Re: Brake light on
Mines still doing it too, brake pedal feels fine, I got sick of looking at it and unplugged it, that'll make it go away
10-08-2009, 04:03 PM | #9 |
Re: Brake light on
when mine used to do that something was out off alignment in the rear the people said who i took it to
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
10-08-2009, 05:11 PM | #10 |
Re: Brake light on
I chased a problem with brake light on for months. Bled brakes numerous times, tried stabbing brakes hard, checked wiring to switch. Finally decided to try a switch off an old proportioning valve and it fixed it. Tested switch after I removed it and it confirmed it was a bad switch (off a brand new proportioning valve).
68 Short Stepside, 350, quadrajet, 700r4, 3:73 posi, power front discs, HEI, Factory Air, Tilt, Tach, accelerator cable instead of rod, sway bar. 96 Impala SS 97 Monte Carlo |
10-09-2009, 12:25 PM | #11 |
Re: Brake light on
Thanks Don, I'll check that
10-09-2009, 01:38 PM | #12 | ||
Re: Brake light on
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
10-09-2009, 02:04 PM | #13 |
Re: Brake light on
might try bleeding the brakes the way they say in service manual with the pin clamped to keep things centered and prevent the lght being on
10-09-2009, 08:17 PM | #14 |
Msgt USAF Ret
Re: Brake light on
The light works because the switch grounds the circuit through the brown wire back to the light. Unplug the brown wire from the switch and if the light stays on the brown wire is shorted to ground and you'll have to find that. If the light goes out then the switch is grounded and it's either a bad switch or one of the other problems already mentioned.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
