Old 07-10-2009, 01:05 PM   #1
JCampbell
Swappin' Guage Clusters
I'll make it quick:
'77 Truck. '83 instrument cluster.
Plug and play?
JCampbell is offline   Reply With Quote
Old 07-10-2009, 01:20 PM   #2
77gmcjoe
What do we get for $10?
77gmcjoe's Avatar
Re: Swappin' Guage Clusters
Not P'N'P.
77 oil gauge is mechanical, 83 oil gauge electric.
1977 GMC K25 400/400/205
1989 Chevy Suburban R1500 350/700R4 (work beater)
1994 Chevy K3500 dually 454/4L80
1996 Corvette LT4 350/ZF 6 speed
2000 Bonneville SSEI Supercharged 3.8 Liter V6
1966 Chevelle 2 door sedan (Needs major repair )
77gmcjoe is offline   Reply With Quote
Old 07-10-2009, 01:25 PM   #3
JCampbell
That's the only difference?
So theoretically, I could swap in the '83 cluster and the only thing not working would be the oil pressure guage?
Old 07-10-2009, 01:34 PM   #4
USSkoval
I do believe the pin locations are different too.
USSkoval is offline   Reply With Quote
Old 07-10-2009, 01:54 PM   #5
JCampbell
Dernit!
The cluster in my '77 is jacked and I wanted to drop in the cluster out of the '83 since it's pretty cherry.
Anybody have a link to a wiring schematic for both years? That would be swell.
Old 07-10-2009, 02:06 PM   #6
flamingbig10
6.0 powered square
flamingbig10's Avatar
you'll have to do a little rewiring, you have swap out the gauge bezel pigtail
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 07-10-2009, 02:10 PM   #7
JohnC
JohnC's Avatar
Yeah not a plug and play, but can be done.
JohnC is offline   Reply With Quote
Old 07-10-2009, 03:20 PM   #8
JCampbell
Good to know...again, anyone have any info on the nuts and bolts?
I'm an Electrician by trade, so a little rewiring doesn't bother me, just need a schematic.
Unless I'm better off swapping the whole dash harness from the '83 into the '77...or am I drinking too much Kool-Aid?
Old 07-10-2009, 03:37 PM   #9
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Here's a bunch of them!
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 07-10-2009, 03:42 PM   #10
JCampbell
Nice! Thanks!
Old 07-10-2009, 05:46 PM   #11
Jonboy
Slots go on anything!
You should be able to re-pin the connector and be fine. It might be easier to find another 77 cluster, though.
Old 07-10-2009, 05:57 PM   #12
flamingbig10
6.0 powered square
if the wiring on the donor truck is good I would swap over the complete wiring harness and also you won't have to mess with the front lighting wiring since your doing 81-87 swap
Aaron
Old 07-10-2009, 06:01 PM   #13
JCampbell
Hmm…according to the schematics, it looks like the pin connectors are essentially mirrored from 77-80 & 81-87.
Can anyone confirm this?
Old 07-10-2009, 06:23 PM   #14
Jonboy
It's the same plug. I had to repin mine when I swapped to a later tach cluster in my '77 Blazer, but I figured it's because of the tach. I would try to plug it in, and see what happens. They both use voltmeters, so it shouldn't hurt anything by plugging them in.
Old 07-10-2009, 07:17 PM   #15
JCampbell
Roger that. Thanks.
Old 07-10-2009, 08:34 PM   #16
USSkoval
I don't think those diagrams are quite listed correctly. I didn't really look them over, but the '77 wiring is similar to the '73-'76 models. The second group should only be '78-'80. '77 had the mechanical oil pressure and windshield wiper wiring, and glass fuses... like the '76 and older. People have put a '78-'80 cluster into the '81 and newer trucks, without issue. But the '77 clusters (and older) do not swap over without work.
Old 07-10-2009, 10:58 PM   #17
N2TRUX
Happy to be here
N2TRUX's Avatar
The main thing to remember is DO NOT put a later cluster in anything 73-76 . It had an "AMP" gauge rather than a "Volt" gauge and it will melt you cluster
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 07-10-2009, 11:23 PM   #18
USSkoval
Would it work with the original AMP gauge installed?
Old 07-11-2009, 12:43 AM   #19
pig rig
pig rig's Avatar
campy just go for it you've got a parts truck and I'm coming down to see you and I know I've got what you need to put it back together
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette
http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG
pig rig is offline   Reply With Quote
Old 07-13-2009, 02:31 PM   #20
JCampbell
You probably right about that.
Old 07-13-2009, 03:34 PM   #21
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Other than not having a working oil gauge the worse that could happen is nothing works.
Historically though, I have had to repin everyone I swapped be it 2 or 10 pins.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 07-13-2009, 03:37 PM   #22
JohnC
JohnC's Avatar
Don't mean to jack your thread, but I picked up a factory tach cluster this weekend out of a 06/81 build date truck. Would I have to re-pin for my 84?
Old 07-13-2009, 04:01 PM   #23
Captkaos
Captkaos's Avatar
for the fuel gauge, most definitely,
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 07-13-2009, 05:49 PM   #24
JohnC
JohnC's Avatar
Cool thanks. Not sure if I want to use it or not, just was curious.
