07-10-2009, 03:20 PM | #1 |
2 different ride heights possible with air bags?
If I had a CoolRide kit on the front and a AIRoverLeaf kit on the back of my '79 C-15 could I use two different ride heights (lower for summer and higher for winter) or is it really important to maintain the recommended 5" bag height at ride height?
Evan B. |
07-10-2009, 10:32 PM | #2 |
VA72C10
Re: 2 different ride heights possible with air bags?
I'm sure someone else will chime in with true bag experience.... but what I have learned from reading on here is the recommended pressure is for best ride comfort. You can do less or more pressure to raise/lower the bags but you will sacrifice some ride quality by doing that buy probably not too much for an inch or two difference.
Looking for a 67-72 swb or blazer project in or around VA. |
07-10-2009, 11:17 PM | #3 | |
You could set up your 'winter' front ride height w/stock spindles & bags & align it there. Then when spring/summer rolls around, swap to some drop spindles for a quick 3" of additional drop. The alignment would ideally need to be re-done but it might be close enough w/o one that the tires wouldn't wear crazy fast. Set up the rear w/a flip kit, 2 main leaves, & AOL. Pop in a lowering block & you're now quickly 2"-3" lower.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 07-10-2009 at 11:25 PM. |
