Old 07-11-2009, 01:15 AM   #1
wancosc356
I Like Mine With No Shine!
wancosc356's Avatar
Polyurethane Experiences
Ok. So I was thinking of doing all of my body mounts and suspension polyurethane. But I have heard that it is stiff and squeaky. Are either of these claims true? Also, could u just "lube" your bushings with something when mounting and every once in a while? Looking for opinions and suggestions. Thanks
Michael
1967 Chevrolet C10 Short Fleet (Literal Ground Up....One Day)
2006 GMC Sierra Crew Cab 4x4
1969 Lincoln Continental Coupe Project FOR SALE
http://67-72chevytrucks.com/vboard/c...ct=4578&cat=17
1981 Honda CM400 C Bobber SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=384152
wancosc356 is offline   Reply With Quote
Old 07-11-2009, 07:56 AM   #2
BigDaddyDave
RIP BigDaddyDave ~7-23-09~ You will be missed~
BigDaddyDave's Avatar
Re: Polyurethane Experiences
It is true, without proper lubrication, urethane bushings tend to squeak. I think they're a little stiff compared to rubber. I could never get mine to stop squeaking and i didn't like the stiffness. It is a personal choice.
BigDaddyDave's Truck: http://www.flickr.com/photos/daves71chevy/ | See it in Action!
BigDaddyDave is offline   Reply With Quote
Old 07-11-2009, 08:07 AM   #3
Bugsy_malonn
Bugsy_malonn's Avatar
I LOVE THEM they are awsome and I wouldnt do a build without them. I worked in a motorsports shop for years and have put a ton of them in. As well as my own cars and trucks. Done right they dont EVER squeak at all. The trick is graphite grease use that stuff and they wont ever squeak I had a honda I put them in and drove it 200,000 miles and never had a squeak at all
71 GMC 1 ton dually tow truck "Cooters tow truck from the Dukes of Hazzard"
1988 chevy 1 ton 4x4
Chevy step van "dont know what to do with it yet LOL"
1940 chrysler
1949 dodge panel rat rod
1989 jeep cherokee
"With a 8 inch lift and a ton of other stuff and two parts jeeps"
Then the wifes van LOL
Bugsy_malonn is offline   Reply With Quote
Old 07-11-2009, 08:24 AM   #4
69GMCLonghorn
69GMCLonghorn's Avatar
I had a Chevelle with all Poly bushings up front. Dang things squeaked for about 6 years until I wore out the ball joints. The guy properly lubed everything and, as mentioned, I NEVER had anothe squeake! In terms of body mounts on these trucks, I'm about to redo mine and may opt for rubber, just because I need all the cushion I can get with 1 ton springs out back.
My front end is in good shape, but if I ever redo it, it will definitely be with poly bushings...
69GMCLonghorn is offline   Reply With Quote
Old 07-11-2009, 09:38 AM   #5
leddzepp
Moderator
leddzepp's Avatar
I have poly cab mounts on one of my trucks. Never had a problem with squeaking myself, but I have heard others say that they have that problem. It is generally recommended to go with rubber on the cab mounts and poly on the suspension parts.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 07-11-2009, 05:23 PM   #6
Shaky
Six in a row makes it go...
Shaky's Avatar
I had a '69 Chevelle that I did the front suspension with when poly first started to be used. Real hard durometer. It handled great and squeaked BAD!
Later I did the front end on a '68 Biscayne with graphite impregnated bushings with a lower durometer. Handled good and no noise.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 07-11-2009, 06:58 PM   #7
wancosc356
wancosc356's Avatar
Thanks for all the input guys. Any more?
Michael
Old 07-11-2009, 08:04 PM   #8
68jewel
On the path to financial ruin!
68jewel's Avatar
I have a 72 Chevelle with polyurethane everything. From body mounts, to front end stuff and bushings in the trailing arms out rear. And I have never lubed anything. No B.S. either. They never squeak or anything. Then too, I don't know if this matters, but I went with all Energy Suspension stuff and not that cheap stuff other sellers are selling. I plan on doing my 68 C10 in all polyurethane too. I have a Porterbuilt Dropmember C4 and and all my Corvette contol arms, both upper and lower, have been redone with Energy Suspension polyurethane bushings.
68jewel is offline   Reply With Quote
Old 07-11-2009, 09:08 PM   #9
Skirkpat
Skirkpat's Avatar
Some of the Poly mounts are impregnated with graphite...I think?
1969 Short Stepside
1969 4 WD Suburban
1970 1 Ton Dually....Misfit
oh, and a 2001 HD 2500, 8.1 Allison Shortbed 4 Door
Skirkpat is offline   Reply With Quote
Old 07-11-2009, 09:19 PM   #10
texanidiot25
Eat My Rust
texanidiot25's Avatar
Poly shock bushings. Well greased and don't squeek a bit, but are noticably stiffer.
My neighbor got a '69 Camaro with everything poly up front. Didn't squeek, but boy that car handled a good bit sharper than I would have imagined. No slop, and pretty dead-on steering.
texanidiot25 is offline   Reply With Quote
Old 07-11-2009, 09:35 PM   #11
68jewel
68jewel's Avatar
Oh yeah, mine are progressively stiffer. But, I like that. I'm more of a sport suspension guy. I don't like all that bouncing around and stuff. To each his own, but me, I like the stiffer sport-like suspension for corner carving.
'72 Chevelle SS--4.0 Whipple LS7, T56 Magnum, 20X9/20X13 HRE 791R, 6-piston Baer brakes, IRS
'68 SWB C10--LS3, TKO-600, 22x10/22x12 HRE 948R, C5 suspension, shockwaves, custom frame
Ooh Wee's Makeover...http://67-72chevytrucks.com/vboard/s...d.php?t=376280
Old 07-11-2009, 09:45 PM   #12
Stocker
20' Daredevil (Ret)
Stocker's Avatar
The Softride front springs I installed several years ago came with poly bushings. I can't remember lubing them with anything, and they have never squeaked.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 07-11-2009, 11:33 PM   #13
wancosc356
wancosc356's Avatar
Anyone have an opinion on Prothane Brand?
Michael
Old 07-12-2009, 12:41 AM   #14
4x4Poet
Originally Posted by 68jewel View Post
'''I don't know if this matters, but I went with all Energy Suspension stuff and not that cheap stuff other sellers are selling...
It matters. ES graphite-impregnated poly body mounts do prevent squeeks. They're softer and slipperier. I agree that there are a lot of cheap poly mounts out there.
And they're a softer durometer so they give a little which allows a ladder frame to flex without fighting it like other brand, too-hard polymounts do.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 07-12-2009, 10:18 AM   #15
Shaky
Shaky's Avatar
Here's what I ordered (make sure you pick the right ones) for my C20. I had good luck with my graphite impregnated car suspension bushings I got from them.
http://www.p-s-t.com/c-210-body-cab-mount-kits.aspx
Old 07-12-2009, 02:12 PM   #16
71 super
71 super's Avatar
I used energy suspension parts in my bb truck and I am using it again in my 4x4, installs easy enough and no problems squeaks etc at all.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 07-12-2009, 04:08 PM   #17
70cst
70cst's Avatar
All I know is this FWIW...Curt who is doing the resto on the Circuit Rider...has been in the Resto business for over 35 years...I asked him which way to go...poly or rubber bushings....Curt didn't miss a beat and said rubber is the only bushings he would recommend. Curt said poly bushings are hit and miss regardless of the brand. He said you might get lucky but if you wasn't lucky did I want to be riding around in a squeak machine? I wasn't willing to take a chance. The idea of possibly having to lube the bushing every so often didn't sound all that much fun. Or what if I could't get the squeak silenced. Sure some have had good luck with poly but I didn't want to a chance. Now the other option is...poly bushings with loud headers... no problem. As I said...JMHO
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 07-12-2009, 07:09 PM   #18
jerry moss
Born Psycho
jerry moss's Avatar
i like them in the suspension but will never use them on body mounts. on a 4x4 or 2wd 3/4 ton, the rear mounts do not compress like the rubber mounts and it throws sheetmetal alignment in the crapper. we tried them on a couple trucks we built and now use rubber only on the body. i still have poly mounts on my 72 cheyenne super (with spacers on the front cab mounts to even it out) and in really off camber rocks/ruts the headliner trim even pops and creaks. they are much too stiff and don't allow proper flex so the cab absorbs the twist instead of the mounts. these trucks are made to flex quite a bit and poly mounts kill 90% in my opinion.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
