Old 07-11-2009, 08:48 AM   #1
2000tj
Will a '69 Chevy fender work on a '72 GMC?
I have a '69 rust free fender that came with my truck when I bought it a few months ago. Several people have told me it will work on my '72 GMC K25, others have told me it will not work. What is different about them? It looks the same just looking at them. The original is still on the truck so I cannot lay them side by side for camparison. Thanks for any help you can give.
2000tj is offline   Reply With Quote
Old 07-11-2009, 08:52 AM   #2
myoldchevytruck
Retired Air Force Veteran
myoldchevytruck's Avatar
Re: Will a '69 Chevy fender work on a '72 GMC?
Sorry, wrong info given. Please see other members post below for correct information on compatibilities.
Harry
69' SWB Step Side 1/2 Ton w/68' Front Clip
Swap from Leafs to Trailing Arms (Complete)
Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front)
3/6 Drop
Help Support The Board
Click Here For Information On How To Subscribe
Krue's FAQ Page
Vendors
myoldchevytruck is offline   Reply With Quote
Old 07-11-2009, 08:57 AM   #3
71swb4x4
71swb4x4's Avatar
Not taking marker lights into account, there are two style of fenders.
Style 1:
67-72 GMC are all the same with the exception of the 67 having no side marker hole.
67-68 Chevy are the same as the GMC fenders, with that side marker hole exception.
Style 2:
69-72 Chevy fenders are the same.
PS - the difference is in the very front of the fender, as you look at it head on. The GMC and early Chevy incorporates the grille into the fender. The later Chevy has the front end recessed so that the grille can fit over the front of the fender.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 07-11-2009, 09:01 AM   #4
2000tj
71swb4x4...Does that mean that the 69 chevy fender will not work?
Old 07-11-2009, 09:06 AM   #5
Thealien
Thealien's Avatar
Correct, like mentioned earlier look at the very front of the two fenders, the chevy will have a recess and the GMC will not. Might be harder to see with the grill installed. If you do a search you will find some pictures.
Old 07-11-2009, 09:56 AM   #6
Mordachai
Fat Fendered Fleetside
Mordachai's Avatar
69-72 chevy style you can see where the grill fits over the fender
(bad pic- I know)
and the 67-68 chevy/67-72 GMC style, you can see where the grill sits inside the fender
technically the 67 would not have the marker light as already said.
but you should be able to spot the difference in the front of the fenders.
hope it helps
71 GMC lwb
56 Big window swb
93 GMC Sonoma (dd)
radiused fiberglass fender project for 67-72
Mordachai is offline   Reply With Quote
Old 07-11-2009, 11:14 AM   #7
myoldchevytruck
Guys, Sorry about the bad info on that 69 Chevy Fender fitting the 72 GMC. I'll delete that post.
Harry
3/6 Drop
Krue's FAQ Page
Vendors
Old 07-12-2009, 09:12 AM   #8
Mordachai
Mordachai's Avatar
no problem.
The fender will physically fit on the truck, all the fender mounts are the same.
just the grill might not look right or fit at all depending on what grill and fender you are running.
I've seen alot of these trucks with mis-matched fenders, including mine. lol.( not anymore- now I got the 1-Pc front in my avatar...)
I have a GMC, and GMC pass fender, but chevy driver's side. It did look a little funny with that front edge sticking out on the driver's side though.
so it'd fit, just look crappy....
71 GMC lwb
56 Big window swb
93 GMC Sonoma (dd)
Old 07-12-2009, 09:59 AM   #9
2000tj
Thanks for the inof everyone. Looks like I need 2 fenders.
