Old 07-11-2009, 11:43 AM   #1
VanceH
Loving the Jimmster
VanceH's Avatar
Benifits or disadvantages to a HEI
The 350 i picked up has a HEI, the 283 i replaced has an old school points set up. I am not liking the Look of the HEI and was thinking about going back to old school. Any thoughts??
thanks
Vance
VanceH is offline   Reply With Quote
Old 07-11-2009, 11:48 AM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Benifits or disadvantages to a HEI
I think HEI looks as ugly as the next guy, but I hate fooling with points. HEI also offers longer plug life, and in my opinion, better mileage and drivability.
Old 07-11-2009, 11:49 AM   #3
68gmsee
Active Member
68gmsee's Avatar
Supposedly you get better gas mileage but it depends on a lot of other factors including the condition of the engine, carb, exhaust type etc.
It will give you hotter spark and slightly better response. Best part is that you don't have to worry about messing with the points.
I've got one on my 68 but left the resistive wire in in case I want to go back to points.
68gmsee is offline   Reply With Quote
Old 07-11-2009, 11:51 AM   #4
VanceH
Loving the Jimmster
VanceH's Avatar
If thats all there is i am going to go back to old school, points seem easier than the inside of the HEI. I remember growing up the old man always had a spare set of points in the glove box!!!
Old 07-11-2009, 11:56 AM   #5
Irishpilot
I agree with all the previous posts. It is all-around better ignition, in my opinion.
1971 C-10, 406ci, restoration begun!
406ci sb; zero decked, bored .030, edelbrock aluminum e-tec heads, edelbrock performer RPM intake, comp 268 cam, comp 1.6 pro-magnum roller rockers, MSD street fire HEI, MSD 8.5mm wires, Holley Street demon 770, Hedman LT headers. 10.6:1 compression, Air Ride Tech bags on all 4-corners.
Irishpilot is offline   Reply With Quote
Old 07-11-2009, 12:00 PM   #6
nds1968
nds1968's Avatar
You can replace the points with Petronix for around a $100 give or take depending on the application. That's what I did to keep it looking original.
Nate
1967 short fleet Project Blue Goose
'If it don't bounce back... heeheehee you go hungry!" Blues Brothers
nds1968 is offline   Reply With Quote
Old 07-11-2009, 12:03 PM   #7
nbrfd007
nbrfd007's Avatar
HEI is the first thing that goes in on my rigs when I get It. Is hard to beat and cheap.
nbrfd007 is offline   Reply With Quote
Old 07-11-2009, 12:13 PM   #8
VanceH
Loving the Jimmster
VanceH's Avatar
cheaper to maintain then old school set up???
Old 07-11-2009, 12:22 PM   #9
Arad68
Trucks N Tranzams
Arad68's Avatar
Like TX says, it is hands down the best. Points are a pain.
Don
'68 Chevy LB 383 TH400/GV/373 posi
'56 Chevy 4WD SWB
'64 Chevy short stepside
'79 Trans Am 455/TH2004R/12blt/4whldisc
95 Kia (Wifes car)
2002 S-10 extended cab pickup
"God punishes small sins immediately"
Arad68 is offline   Reply With Quote
Old 07-11-2009, 12:33 PM   #10
vectorit
What?
vectorit's Avatar
HEI is better than the point set up, but...
I have been left stranded in the worst place one could be stranded due to the stupid module inside the HEI, at least when the points start to go bad you can tell. The HEI module doesn't give you any warning, so it just stops working and shuts you down where you are. (At least in my experience).
If I were to go with HEI again, I'd carry that module in the glove box. Just like all us point guys, that carry an extra set of points...
Really, the electronic set up is the way to go. I just run points for the fun of it, and just to keep it orignal looking. But, I do think the Pertronix set up is in my future.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 07-11-2009, 12:34 PM   #11
bbadfred
bbadfred
bbadfred's Avatar
Yes longer sparkplug, cap and rotor life, easier starting ( save on batterys and starters) As others said better response,more horsepower. Don't you think there was a reason dad had spares in the glove box? If points were so good why have they gone the way of bias ply tires, drum brakes, 20k mile tune ups ect?
bbadfred is offline   Reply With Quote
Old 07-11-2009, 01:20 PM   #12
69GMCLonghorn
69GMCLonghorn's Avatar
As someone told me once, the engine only needs so much spark to run. You can feed it a million volts, but if it doesn't need it, it's pointless (no pun intended). yes, HEI is nice, but let me tell you, I have the Pertronix in my truck. On the rare winter morning in LA where it's down around freezing, i can jump in it and fire it up on the first try... and I have NO CHOKE on the carb! This is all thanks to the Pertronix... Just make sure your coil is in good shape. If not, get the matching Pertronix coil and be done with it. No brain tumor of a distributor needed.
Again, to the HEI fans, I apologize and I can't knock it. If it wasn't any good, nobody would use them. It's just not entirely necessary.
69GMCLonghorn is offline   Reply With Quote
Old 07-11-2009, 01:50 PM   #13
Pont406
I run HEI. I remember blowing up mufflers because of bad points.
Couple things to consider with HEI is that it was set up for smog motors. Way too much vacuum advance and lazy mechanical advance. I changed center plate and weights before use.
Pont406 is offline   Reply With Quote
Old 07-11-2009, 01:59 PM   #14
hilandr452
hilandr452's Avatar
You must be a subscribing member to make WTT (want to trade) offers.
Please review the rules:
XIV. As of October 15th 2005 subscribing members will be the only ones permitted to post for sale and want to buy ads on any classified section of this site. All other rules of buying and selling still apply. 67-72chevytrucks.com, its administrators or staff are not responsible for any transactions on or off the forums. We will work hard to ensure you a smooth transaction, and help in the event you may need it, but all for sale and trade areas are buyer beware. Any persons who have misrepresented an item, lie about an item, fail to deliver, or are in violation of any of the rules will forfeit there subscription fees and be banned from 67-72chevytrucks.com
Dan Smith
Colorado Springs, CO
71 GMC Custom Camper "Longhorn" 454, TH400
73 Chevy Camper Special (Yes, it's badged a camper special) Flat Bed Motorhome conversion 454, standard tranny
"DON'T TREAD ON ME !!!"
My Project: http://www.picturetrail.com/sfx/album/view/20829244 , http://www.picturetrail.com/sfx/album/view/24654442
hilandr452 is offline   Reply With Quote
Old 07-11-2009, 02:18 PM   #15
Ackattack
Ackattack's Avatar
can't you get a small cap HEI distributor with an external coil?
To be honest, I don't like distributors......just get rid of them and run a gen III engine
Ackattack is offline   Reply With Quote
Old 07-11-2009, 02:22 PM   #16
mikajo39
Gearhead and audio junkie
mikajo39's Avatar
That's how my last muffler left this world, and the reason I couldn't hear anything out of my left ear for a couple hours, BOOM! HEI is nice, I do wish the friggen cap wasn't as large as it is, but i really dig the one wire and you're rolling setup.
mikajo39 is offline   Reply With Quote
Old 07-11-2009, 02:49 PM   #17
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
HEI is it for simplicity. If you have a clearance issue, run a mag pickup. I have the MSD 85551 and love it. Only switched from my HEI due to clearance.
prostreetC-10 is offline   Reply With Quote
Old 07-11-2009, 03:35 PM   #18
jbristo67
resident oilfield trash
jbristo67's Avatar
HEI it doesnt look that bad + no one sees it with the hood closed
1967 SWB C10 396/400 factory air
factory tach (sadly had to send to a new home)
1986 Honda 70 Fourtrax
1991 Chevrolet K5 blazer 2wd
1982 Mastercraft Pro Star 190 Stars and Stripes
2002 Chevrolet Tahoe
2011 Nissan Armada
jbristo67 is offline   Reply With Quote
Old 07-11-2009, 03:42 PM   #19
Sinister
Between Trucks...
Sinister's Avatar
Originally Posted by jbristo67 View Post
hei it doesnt look that bad + no one sees it with the hood closed
x2
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 07-11-2009, 03:44 PM   #20
leddzepp
Moderator
leddzepp's Avatar
I can't even see mine. The air cleaner hides it.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 07-11-2009, 05:30 PM   #21
hilandr452
hilandr452's Avatar
My bad,
I thought it was pertaining to selling and buying only. I stand corrected. I'll take it to PM's.
Dan Smith
Old 07-11-2009, 05:46 PM   #22
cparman
sharp as a marble
HEI in both of mine. I have also done a bunch of Pertronix installs. The only thing I have against the pertronix, is if it fails you are stuck for a day or two depending where you live. With the HEI, every parts store in this country has parts for it.
cparman is offline   Reply With Quote
Old 07-12-2009, 01:49 PM   #23
BP68
BP68's Avatar
In a way yes. Point may be cheap, but the only maintanence of the HEI is a cap and rotor when they wear out which should be many, many, many miles. And the odd chance the ign module goes out.
I went with a GM performance HEI from Jegs in mine. Put it in, set timming and forget it.
I say if you want old school look, at least put Petronix modern guts inside.
68 C10 Shortbed Fleetside
06 Chevy Ext Cab Fleetside
03 Grand Prix GTP
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=269999
BP68 is offline   Reply With Quote
