07-11-2009, 01:41 PM | #1 |
SWB on a 67 SS Chevelle frame? Can it be done?
Has anyone done this? they have about the same wheel base so what other problems will i run into? also i want to use the Chevelle 12 bolt will i run into problems with that? let me kno what you think about my possible next project!
68 C10 LWB 2/4 drop 406/th400/3.73posi 04 Silverado SS LQ9 6.0/4L65e/4.11posi AWD |
07-11-2009, 01:53 PM | #2 |
Re: SWB on a 67 SS Chevelle frame? Can it be done?
My dad had a '63 swb pickup that we put on a '78 olds delta 88 frame. It was the same wheel base also. Its been a while ago, but I know he had to cut the floor near the back and box it in. Of course everything had to have custom made mounts to mount the cab, bed, and front clip. Anything is possible, just depends on how much work you want to do to make it work. The easy route would be to use a stock frame and customize it with which ever rear you wanted. One thing though, the olds frame we used rode like a caddy, and we got it pretty low with a stock suspension. The wheel bolt pattern was the same as the trucks if i remember right. Good luck and let us know what you decide.
07-11-2009, 02:54 PM | #3 |
My Carbon Footprint
These days anything can and has been done. It's just a matter of ease. There are always long and drawn out ways of doing something and shorter ones. I would just guess that there would be a ton of changes just to get the body on. If it was me, I'd find a long bed frame with a 12 bolt and cut the frame before taking on that kind of challenge. It would be one thing if you have a really old truck and you are trying to upgrade from a straight axle front but that is not the case here. Would sure make for a cool build thread though!!!!
07-11-2009, 04:13 PM | #4 |
The thing is that I have a great frame for the tru k but just wanted something that would handle awesome and ride great! I plan to make a hotrod out of it that not many ppl have
07-11-2009, 04:23 PM | #5 |
My Carbon Footprint
Just ask around this board.....you can get these truck frames to handle like they are on rails!
Just a guess but if you are wanting handling, I'm thinking the chevelle frame might be too narrow. |
07-11-2009, 04:42 PM | #6 |
Man, before I would go thru all the mods required to do what you want. I would check into getting a air bag system. They make them where you can get the truck to handle like it's on rails, and ride better than a caddy.
One trick you can do is swap your upper control arms from right to left. it changes the angle of the wheels so when your turning more of the tire stays on the road.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box. * You may be only one person in the world, But you may also be the world to one person. * Some mistakes are too much fun to only make once. Two rules in life. 1. Never sweat the small stuff! 2. Everything is small stuff! |
07-11-2009, 04:46 PM | #7 | |
My Carbon Footprint
WOW....now I have not heard about this one. Does it change the caster or what? This is very interesting. Where can I get some more info on this? Thanks! |
07-11-2009, 05:41 PM | #8 |
its all about the +6 inches
in reality, I don't think the chevelle frame would offer much (if any) advantage in the way it would handle.
07-11-2009, 05:47 PM | #9 |
I am a Referee of life.
40 year old tech swapped for 40 year old tech probably wont net you much better handling other than the lowered stance and center of gravity.For the same $$$$ and effort you could probably do both to your truck frame.The only advantage I can think of is that the Chevelle will have better aftermarket support for handling mods and suspension pieces.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
07-11-2009, 06:36 PM | #10 |
Happy to be here
All you need to do is add the right equipment to a SWB frame. It looks to me like the truck is burning the cones just as flat as the Chevelle.
Get er low and make er go....
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 07-11-2009 at 06:37 PM. |
07-11-2009, 06:50 PM | #11 |
My Carbon Footprint
Great comparison! That 66 looks tough too!
07-11-2009, 10:22 PM | #12 |
if the 'velle frame is nice, the selling of it would probably fund most of the truck suspention mods.
07-12-2009, 02:53 AM | #13 | |
Green club
Never heard of this, any more info?
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears 70 SS396 Chevelle 427/200-4R/3.73posi 61 Lincoln Continental, black on black Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln |
07-12-2009, 04:27 PM | #14 |
Factory Strippers Rule!
Anyone with more insight on this?
07-12-2009, 07:50 PM | #15 |
I believe the truck will handle worse with the under-rated suspension of the car.It wouldn`t be sitting like those pictures.
07-12-2009, 08:08 PM | #16 |
Saving 1 truck at a time!
Frizzle Fry ran his big block Burby at an autocross with minor modifications against English, German and Italian sports cars. He finished about 30 out of 40 or so. Not sure how to find that thread with the Utube link!
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
07-13-2009, 10:09 AM | #17 |
I own and drive chevelles. If you want them to handle well you still need to throw parts at them!
Have you heard of "Hot Rods To Hell" they use 2wd trailing arms to make chevelles handle awesome! This is what they did in NASCAR decades ago. With the aftermarket support we have today, you can buy or build suspension parts to make your truck do whatever you want it to do. I think the frame swap will be a lot of unneccesary grief. But to each his own.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
