Old 07-11-2009, 03:02 PM   #1
Jack_71C10
Shortbed club member
Jack_71C10's Avatar
Quick A arm question
My upper A arm is worn and clunks when I hit bumps.
Do I need to replace with a complete upper A arm, or
can I just replace the A arm shaft.
Basically, what usually wears in this situation.
Jack_71C10 is offline   Reply With Quote
Old 07-11-2009, 03:27 PM   #2
SCOTI
SCOTI's Avatar
Re: Quick A arm question
Are the arms original to the truck or is there a possibility they were replaced w/some 73-87 arms?
The bushings for a 71 upper arm are rubber lined steel. The don't usually wear to the point of 'clunking' but it's possible. Are the alignment shims tight on the upper a-arm shaft where it attaches to the crossmember/frame? If some shims fell out, it would definitely cause some shifting of parts & give an audible 'clunk' when doing so.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-11-2009, 03:39 PM   #3
Jack_71C10
Jack_71C10's Avatar
I can push & pull on the A arm and see it move while the shaft stays solid.
Old 07-11-2009, 03:40 PM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Bad bushings then. They are available through all typical parts stores.
Old 07-11-2009, 03:44 PM   #5
Jack_71C10
Jack_71C10's Avatar
Thats sortof what I thought. But when I looked at the lmc catalog
they only show a seal and a end nut, no bushing.
Old 07-11-2009, 04:35 PM   #6
Tx Firefighter
That big nut on the end is the bushing itself. You have the screw in bushing and the little rubber seal. That's it.
LMC is going to overcharge you for this kind of stuff though. Local parts stores are cheaper for good quality stuff. LMC just resells stuff that they buy.
Old 07-11-2009, 05:02 PM   #7
Jack_71C10
Jack_71C10's Avatar
Thanks for clearing that up for me TX.
Thats what I was unsure of.
was going to buy locally, just using lmc as a guide.
Old 07-11-2009, 07:29 PM   #8
lowdownstar
big guy
lowdownstar's Avatar
I have an upper set of A arms if you need them. Free just pay shipping and there yours.
Ray
lowdownstar is offline   Reply With Quote
Old 07-12-2009, 10:48 AM   #9
DHPmike
DHPmike's Avatar
You are better swapping them with the later arms that have rubber bushings. The length is the same and so is the bolt pattern for the balljoints. You can also but the replacement shaft and bushings at many chain auto parts stores
DHPmike is offline   Reply With Quote
Old 07-12-2009, 03:34 PM   #10
Shane
Shane's Avatar
Why are the later with rubber bushings "better" ?
Shane is offline   Reply With Quote
Old 07-12-2009, 03:57 PM   #11
SCOTI
SCOTI's Avatar
'Better' would be a subjective term.
The later bushings are more readily available & offer more 'cushion' for the high quality roads that 'daily drivers' seem to face everywhere. The earlier bushings would be 'better' from a performance/non-deflecting stand-point.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-12-2009, 04:35 PM   #12
DHPmike
DHPmike's Avatar
yes for an every day driver the rubber is better. if you want to feel every little pebble in the road the original bushings are better.
Old 07-12-2009, 06:39 PM   #13
Shane
Shane's Avatar
I'm thinking the tires have a lot more to do with feeling every little pebble in the road than the a-arm bushings ...
I only asked because I have used both and to be completely honest I cannot tell the difference sitting behind the steering wheel. I thought there was some fact-based reason for using the rubber over the solid bushing type, but apparently it's personal preference.
Old 07-12-2009, 08:02 PM   #14
DHPmike
DHPmike's Avatar
vibration, a small amount but still vibration, just like the engine mounts and rubber in the steering column. Tires may have more to do with it but every place metal touches metal theres vibration transferred.
The ultimate would be tube arms with poly bushings but it all depends on funds and prefrence.
Old 07-12-2009, 10:08 PM   #15
XXL
Seņor Member
XXL's Avatar
And one of those donut pillows to sit on.
XXL is offline   Reply With Quote
Old 07-13-2009, 09:35 AM   #16
dznucks
dznucks's Avatar
where does the control arm bushing fit in, then?
i have never rebuilt a control arm but am about to.
dznucks is offline   Reply With Quote
Old 07-13-2009, 09:40 AM   #17
SCOTI
SCOTI's Avatar
The 'bushing' is a metal sleeve w/rubber lining the outer portion on the 6X-72's. The 73 & later arms have an actual rubber bushing in a steel shell.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-13-2009, 10:22 AM   #18
Tx Firefighter
To add to Scoti's response.
The control arm has a huge threaded hole in it. The bushing is the steel cap, which has threads on the outside of it. You screw the steel bushing into the threaded hole in the arms. Frankly, it's a real *****. In the past few years, I have started to run 73-87 arms simply because it's dead easy to press new bushings in place. Plus, I can get a full set of Energy Suspension control arm bushings for 73-87 arms for 60 bucks. The older arms with the steel bushings cost way more than that to get buy good bushings.
Old 07-13-2009, 12:11 PM   #19
chevy_mike
Never Ending Projects
chevy_mike's Avatar
BTW, the upper bushing nut is a 1 3/16" and the lower nut is a 1 5/16".
I ended up taking my arms to a buddy's shop and used their 3/4" drive impact to get them off. I got to do it for free instead of buying $100 worth of sockets and an adapter to my 1/2" drive impact.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 07-13-2009, 01:12 PM   #20
dznucks
dznucks's Avatar
so maybe i should find some 73-87 A arms. do they bolt right up? just different bushings.
Old 07-13-2009, 04:48 PM   #21
SCOTI
SCOTI's Avatar
That's correct. They're a direct swap but use different bushing material.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-14-2009, 08:34 PM   #22
pritch
pritch's Avatar
I'm in the middle of this very thing right now. I was going to re-use all my old stuff, but I didn't like the way they were going on so I ordered new shafts and bushings.
A couple more questions-As the bushings thread into the arms, should the shoulder of the bushing/nut thread in all the way until it makes contact with the arm? Seems like I can get either the front or rear to touch, but not both.
And how-which way-do the seals go? They are different, top and bottom of course, but which is the inside face? Any pictures of properly installed seals?
'68 Panel
Project Boogie Chillin'
'68 C-10
Ol' Green
pritch is offline   Reply With Quote
