Old 07-11-2009, 08:36 PM   #1
teamradrz1
teamradrz1's Avatar
Need help
I just installed a newly shortened and balanced driveshaft for my 71 K5 Blazer has 3/4 ton axles and he put a 3/4 ton yoke on the driveshaft to match the pumpkin yoke. Looks perfect but I drove the truck home with the original shaft that was too short and everything was OK put the new shaft on and drove down the street fine but as soon as I hit the brakes softley was only going like 20MPH I heard and felt a Vibration sounded like my nobby tires hitting the fender. doesn't do it taking off or traveling down the road but when I use the brakes it's there pretty consistantly. I'll call the shop Monday but wanted to hear any ideas?
1971 Chevy Blazer CST 4X4
2012 Camaro 2SS/RS
2007 Avalanche 4X4
teamradrz1 is offline   Reply With Quote
Old 07-12-2009, 11:21 PM   #2
GruntMoanCough
GruntMoanCough's Avatar
Re: Need help
Could be related to pinion angle or different yoke?. I dunno.
I suggest talking to your driveshaft guy, I doubt if he'll be pissed, he'll probably be helpful.
Good luck!
My goal in life is to be as good a person as my dog already thinks I am - Unknown
GruntMoanCough is offline   Reply With Quote
Old 07-13-2009, 12:52 AM   #3
teamradrz1
teamradrz1's Avatar
Re: Need help
Yeah I was just hoping to try a few things to resolve so I don't sound like an idiot if it is something I am doing wrong
2012 Camaro 2SS/RS
2007 Avalanche 4X4
Old 07-13-2009, 05:42 AM   #4
Blazer1970
Blazer1970's Avatar
Re: Need help
How much lift do you have? It sounds like one of the u-joints might be binding when the pinion dips under the braking force. Or maybe the splines are bottoming out in the slip joint.
Blazer1970 is offline   Reply With Quote
Old 07-13-2009, 07:19 AM   #5
Re: Need help
The driveshaft should sit center,or close,of the splines when static.It almost sounds like a rear end noise you are describing.But,I`m not hearing it.I`d just go back and ask them to check it out.Don`t say what you think it is.Just tell them what you are telling us and let them assess it.
Old 07-13-2009, 08:15 AM   #6
OLDCHEV4X4
OLDCHEV4X4's Avatar
Re: Need help
I had a simular problem on my motorhome. It turned out that a grease fitting was rubbing the rear yoke, but only under braking. So i removed the rear u joint, and turned it so the grease fitting was facing the front of the vehicle. Fixed.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 07-13-2009, 10:02 AM   #7
Skirkpat
Skirkpat's Avatar
Re: Need help
I was always told to index the grease zert whan replacing the u-joint? I was told to make sure that it was being compressed by the rotation, and not "pulled apart" by it. (don't know if it is true, but I do it anyway?) Maybe if you unhook the drive shaft ad spin it 180 degrees in the driveshaft , it might help?
1969 Short Stepside
1969 4 WD Suburban
1970 1 Ton Dually....Misfit
oh, and a 2001 HD 2500, 8.1 Allison Shortbed 4 Door
Skirkpat is offline   Reply With Quote
Old 07-13-2009, 11:08 AM   #8
teamradrz1
teamradrz1's Avatar
Re: Need help
Thanks guys I'll look into those ideas I'm kinda leaning toward the angle of the pumpkin is there a way to fix that?
2012 Camaro 2SS/RS
2007 Avalanche 4X4
Old 07-13-2009, 11:10 AM   #9
teamradrz1
teamradrz1's Avatar
Re: Need help
When I installed the shaft I pulled it out about 1.5-2 inches to meet the tranny yoke and he messured between the yokes to make the driveshaft length.
2012 Camaro 2SS/RS
2007 Avalanche 4X4
Old 07-13-2009, 12:29 PM   #10
Skirkpat
Skirkpat's Avatar
Re: Need help
They make angled shims
1969 Short Stepside
1969 4 WD Suburban
Old 07-14-2009, 01:23 AM   #11
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Re: Need help
I was also thinking the same thing. Remember my buddies old truck had the same problem pretty much and it was a grease fitting that was rubbing but really only happened under braking. Good luck
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 07-14-2009, 01:28 AM   #12
teamradrz1
teamradrz1's Avatar
Re: Need help
OK called the driveline shop this morning and he had me bring in my truck, mile away. We found that the u-joint caps on the inside are hitting the pinion yoke bolt when braking. So he measured my driveshaft degree angle and suggested I get 4 degree steel shims and that would take care of the issue and still be within the correct range of angleto match the transfer case. He told me where I can get them so I'll call them tomorrow I can't imagine them being very expensive.
2012 Camaro 2SS/RS
2007 Avalanche 4X4
Old 07-14-2009, 04:11 AM   #13
Eturnit3
Bloodied Knuckles
Eturnit3's Avatar
Re: Need help
diy4x has em too if your wanting to shop around.. Also, Im lovin the look of the blazer, that thing gotta thread? Also that's funny, post #2 nailed it
Eturnit3 is offline   Reply With Quote
Old 07-14-2009, 11:38 AM   #14
teamradrz1
teamradrz1's Avatar
Re: Need help
diy4x is that a member or vendor here or a online vendor?
here is the link to my Blazer thread
http://67-72chevytrucks.com/vboard/s...d.php?t=191072
2012 Camaro 2SS/RS
2007 Avalanche 4X4
Old 07-14-2009, 04:30 PM   #15
Eturnit3
Bloodied Knuckles
Eturnit3's Avatar
Re: Need help
Maybe? www.diy4x.com they just make some cools stuff for our trucks..
Old 07-14-2009, 10:26 PM   #16
teamradrz1
teamradrz1's Avatar
Re: Need help
bought the shims and the leaf bolt extenders locally for $40 so same price without the $12 to ship but thanks for the info as it gave me a price point.
2012 Camaro 2SS/RS
2007 Avalanche 4X4
